Battery Wiring thru Firewall Issues?
Old Jun 23, 2006 | 12:16 AM
Epon's Avatar
Epon
8th Gear
Default Battery Wiring thru Firewall Issues?
Since the battery is on the passenger side of the car, I can't simply run a wire thru where the clutch would be. Any suggestions?
Old Jun 23, 2006 | 09:30 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you pull out the battery you will see a big grommet that the main harness goes through. Their is plenty of room to jam wires through it without removing the grommet. I was able to get a 0 gauge wire through.
Old Jun 23, 2006 | 11:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! Then it is easy to feed the wires where ever you need them!
Old Jun 23, 2006 | 11:45 AM
DPG's Avatar
DPG
St. Jude Donor '06
also if you come into the audio section and go to the FAQ at the top, you'll have pics as well with where the taped up grommet is and what it looks like. also make sure you add some lube before you try pushing cable through. it'll make it easier pushing the bigger guage wire through
Old Jun 23, 2006 | 11:47 AM
Epon's Avatar
Epon
8th Gear
Thanks guys, appreciate it!
To Battery Wiring thru Firewall Issues?
