Location of Remote Receiver
Can anyone tell me the location of the receiver that gets the signal from the key fob to lock/unlock the door/trunk. My key fobs don't work (both of them). I've tried resynchronizing and they still don't work. I suspect that it's the receiving unit for the key fob remote and would like to take a look at it at the very least (perhaps it's a loose wire or antenna). Thanks.
Cruising
I started to pull off this molding and only saw the release for the gas cap. Am I close? I am always nervous about pulling off moldings in the event that I can't get them to go back in just right.
My symptoms are:
1) One day the FOB just will not open anything. No panic, doors, trunk, anything. (Fob Batteries are 4 months old)
2) Tried 7 sec reset near the car. Nothing.
3) Tried other FOB. Nothing.
4) Tried the full resync from the instrument panel. The car went through the steps fine, but never recognized the FOB.
I am thinking that the receiver is dead or the antenna disconnected. I need the following if you would be so kind - Location of receiver. Possible fuse issues. Antenna location. Magic wand.
2000 LS1 Vette
Corsa Exhaust
29k miles
Thank you in advance.
Acer288
My symptoms are:
2000 LS1 Vette
Corsa Exhaust
29k miles
Acer288
Cruising
Sigh... I figured how could both my FOBs with only 4 months on the batteries go dead at exactly the same time. This is further puzzling as one of the FOBs nevers leaves a drawer in the kitchen. After reading timemender's post I started thinking that this would be possible if they emitted a continious, or "chirped" pulse to stay sync'd with the vehicle. I am not sure if this is true, it just makes sense to me.
Long story short, I changed the battery in my main FOB and it works as good as new. Thanks for the magic wand timemender.
I'm having trouble with my tire pressure monitor, and I believe that is shares the reciever with the key fobs. It IS located in the left rear quarter panel, and you have to remove the LH side interior trim.
I tried to get the panel(s) off, but the first obstacle was a "tinnerman nut" (like the ones that the factory puts on brake drums and rotors), as well as an awkward working position. I'm going to try again over the weekend.
I'm hoping my problem is also something like a loose/corroded connection. IIRC, the receiver module is a $75-80 part.
The receiver is located behind the side trim panel on the drivers side. The trim panel is held in place with 2 sided tape or something like that along the top where it meets the body panel. You have to take a knife or similar and slide between the body panel and the trim panel to remove it. Once that is out you will see the receiver along the top of the body.
The receiver is over $200 for the part. You should have a message on the DIC that there is no communication. More likely your fobs are bad.
Switch the "Passive" switch on both FOBS to the "OFF" position and leave them there.
Since I just can't get my TPM sensors to properly "link up" to the car, I'm going to take a stab at it, and replace the receiver. $75 shipped, from Fred Beans's parts department. (For an '01)
I bought a used 03 corvette from a Chevy dealer. Since day 1 the fob didn't work unless you were within 5 feet of the car even after changing the batteries in both fobs and reprogramming them. I found this old thread when I was searching common issues on google. So I feel others are going to see this still. I purchased invisible glass because I wanted something safe to clean my tinted windows. This product worked phenomenally. After doing so, my key fob now works from very far distances. My guess is some kind of invisible film must have been on the glass. I don't know if it's from age or people using windex. Or maybe there is something in invisible glass that helps almost like an antenna. I'm curious if anyone would know why and also to try it.
