starter problem?
Old Jul 4, 2006 | 08:13 AM
dima's Avatar
dima
Default bad ground or starter problem?
got the car started this morning by turning key off and on quickly, after 3 or 4 turns, it started, battery is reading 14 v. looks like i have a starter problem.
Old Jul 4, 2006 | 09:26 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
ok..I musta missed a thread.....did you have to turn the key on and off to get it to turn over or to get it to start?? if the first issue then its something else...if the latter then probably the starter...which BTW will screw up your flywheel
Old Jul 4, 2006 | 09:56 AM
dima's Avatar
dima
at first i thought it was the battery, that checked out ok. when i turned the key, i just got a click sound, would not start but everything else would function. today i decided to turn the key several times quickly and on the 3rd or 4th turn it started. ran fine, no problems, everything else seems ok. shut it off and restarted with no problem, i'm letting it sit a few hours and will try again to see if it starts. i want to locate the problem so i can drive it with out worry.
To starter problem?
