Spongy Clutch Pedal??
The clutch on my 03 engages at about 90% of the pedal throw, meaning I have to be just about at the floorboard for the clutch to engage. My clutch is not slipping at all. Any suggestions? Thanks!
I have not checked the fluid.. Is it beneath the car? Could it just be that the fluid is low? EDIT: it is the original clutch.. it has been a gradual change over the past 5000 miles
Clutch Pedal Woes--Fluid Impact
C6Z06 Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
After you've review them, post up any questions.
Probably have some nasty clutch fluid that will take a concerted effort to get cleaned up. But once you do, the pedal behavior will probably improve.
Ragner
