Differential Fluid, which do you use?
Old Aug 8, 2006 | 03:53 PM
Bills03Coupe's Avatar
Bills03Coupe
Default Differential Fluid, which do you use?
I'm about to change my differential fluid and would like to hear your recommendations for which fluid and/or additive you prefer.
I've researched this to death, and there are so many differrent opinions, it's very confusing! Are you using the GM fluid with the full 4oz of GM additive? Redline or Amsoil without additive? Mobil 1 with additive? Any help would be greatly appreciated!
Old Aug 8, 2006 | 04:44 PM
Lancer033's Avatar
Lancer033
Mobil 1, Redline, Royal Purple, and Amsoil are all top quality products and you'll be fine with any of them. I have Royal Purple in my Trans and Diff. only because it is sold at AAFES and that was the only synthetic trans fluid I could get locally.
Old Aug 8, 2006 | 07:12 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I used Amsoil and no additive needed. No problems.
Old Aug 8, 2006 | 07:56 PM
rws.1's Avatar
rws.1
Mobil 1 synthetic 75W90 + GM additive.
Put the full 4 oz additive in first
Why?
I believe in deep pockets... Exxon Mobil has much deeper pockets than Amsoil or Royal Purple.
The can't afford to market an inferior product.
Old Aug 8, 2006 | 08:42 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Royal Purple Max-Gear 75w90...
Old Aug 8, 2006 | 09:19 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
AMSOIL SVG 75w-90
No additive needed. 10000 miles no problems!
Old Aug 8, 2006 | 10:05 PM
ROJ#79's Avatar
ROJ#79
Red LIne for me. It stopped my Diff. Leak!
Old Aug 8, 2006 | 10:28 PM
SLPRC5's Avatar
SLPRC5
All my fluids are RP
Old Aug 8, 2006 | 11:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
My whole car gets the purple stuff and the differential is quieter and trans MN6 shifts eaiser
Old Aug 9, 2006 | 12:31 AM
UstaB-GS549's Avatar
UstaB-GS549
Royal Purple. I suppose the other synthetics are good too.
Old Aug 9, 2006 | 05:43 PM
Bills03Coupe
Thanks for the help Guys!
Any others????
Old Aug 9, 2006 | 06:04 PM
Dirty Howie's Avatar
Dirty Howie
I used Mobil1 and my rear started leaking ..... I'm back to stock fluid
DH
Old Aug 9, 2006 | 06:37 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Do you guys really think the fluid type causes or fixes the leaks?
Old Aug 9, 2006 | 08:50 PM
Mike Mercury's Avatar
Mike Mercury
I was going to suggest the factory fluid too. Unless the car will be heavily raced, why not continue to use something that has proven itself?
Old Aug 9, 2006 | 09:36 PM
LoneStarFRC's Avatar
LoneStarFRC
Nope.
Old Aug 10, 2006 | 12:33 AM
Westwopper's Avatar
Westwopper
I used GM's Synthetic Fluid.... Mostly because I like the new Grape Scent!
Regards,
Tony
Old Aug 10, 2006 | 01:43 AM
Vette_Fan's Avatar
Vette_Fan
Proven to leak? Well, I'm getting a used diff to replace my 2.73. Its coming from a Z06, and the guy had used Redline, with 37K miles and no problems. I think I'll continue with Redline, and keep my fingers crossed. Any of these high end oils is good, but the problem is in the design and materials used in our diffs...
To Differential Fluid, which do you use?
Old Aug 10, 2006 | 05:01 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Redline with no additional additive..........
Old Aug 10, 2006 | 08:52 AM
stonecoldsaysto's Avatar
stonecoldsaysto
Default rear end fluid !!
I had just installed the GM synt fluid & the 4oz bottle of Posi-fluid & then noticed the r/end sticking or screeching around corners/turns.
i then installed the ROYAL Purple from Auto Zone(which has posi fluid already added) & NOW the noise seems to be gone -- still not sure yet if BOTH REAR WHEELS are locked /turning at the same time - taking a trip - so will see if if works or brakes !!!!!!!!!!!!! but at least its quiet now
STILL DONT UNDERSTAND POSI & LIMITED SLIP DIFFERENCE & how they are supposed to work on C-5's (1999 w/315 axle stock)
Keith
Old Aug 10, 2006 | 06:13 PM
Westwopper's Avatar
Westwopper
When I changed my fluid, i added the "friction modifier" first. Then I added the Synthetic AC Delco fluid. You are supposed to take it very easy initially. The first 2 turns the rear chattered a bit. After that, no chatter, no noise.
The issue with this: it is my understanding that the chattering is better for track use since there is less slipping so less heat.... or so I'm told. I would try Redline next time since it is considerably cheaper than the synthetic AC Delco stuff.
Late,
Tony
