Dynatech vs Stainless Works Longtubes
I am more concerened with fit, finish, lasting and other opinions.
Thanks guys for all the help keep it coming!
Then we have the collector itself. This is what a traditional collector looks like...
This is the kind of collector you'll see on a good quality header like American Racing, or LG. It's a merge collector that shrinks down right after the primaries then goes back up to the size of your exhaust, essentially speeding up the air flow in the exhaust, and in turn causing your car to make more power.
This is just my experience from what I've seen in making headers. Another thing we could go into is coatings, and how much I dislike them on headers
Ceramic coated headers always seem to cause detonation. Why? Well everybody jumps on this bandwagon of wanting to keep underhood temps down. Which is great, I love it, whatever you can do to keep underhood temps down is going to help make the motor produce more power. But what we're doing by ceramic coating the headers is we are locking that heat inside the exhaust... Not allowing it to dissipate... This heat now acts as an agent in producing detonation. Almost every car I've ever tuned that had ceramic coated headers, was not able to take as much ignition timing as a car with uncoated stainless steel headers. So the power was greatly reduced because instead of tuning for all out power, I had to tune for detonation. Extra fuel, and less timing... Things that have a great effect on what kinds numbers your car will put down on the dyno, and at the track.Chuck @ HPE
281-448-1300
281-448-1300
281-448-1300
Most LT headers run very close to the clutch lines and really heat the fluid... even with mine wrapped w/ DEI heat tape I still have to flush the clutch often.
I'd think a coated header would simply move the heat down stream and further down the exhaust.
The guys at Extreme did some mild re-adjusting for me with a long bar and tac welding.
I probably should complain to SW and get a new right header. Except that means me re-metal finishing a new header. Grinding off the SW badge, cutting off the unnecessary/unused dipstick mount and Jet-Hot coating the new header.
Not to mention getting under there and installing the new one!
's too
