Fog Lights Not Working
Old Aug 21, 2006 | 09:15 PM
spdnman's Avatar
spdnman
Default Fog Lights Not Working
My fog lights do not work, but they did go on yesterday intermittently. So the bulbs work. I checked the one fuse and its ok. The power switch is lit up as well. Any ideas where I should look? What could be the cause of the problem? Thanks
Old Aug 21, 2006 | 10:59 PM
DeeGee's Avatar
DeeGee
First thing I'd do is pull the switch and make sure the connectors are on tight at the back. The length of the wires is quite short. Its possible for them to work loose.
If both are either on or off its more likely to be at the switch end than the lamp end.
I can E Mail a wiring diagram if it helps.
Old Aug 22, 2006 | 12:06 AM
JC in XTC5's Avatar
JC in XTC5
If the problem is intermittent, it's likely either the fog relay - #39 in the underhood fuse panel, or the ground G102 (and SP100).
One way to confirm the relay is to switch the #39 fog relay temporarily with #36 Horn Relay (both in the underhood panel near the battery). Both these relays should be the same, so if after the swap the fogs work and the horn is intermittent then you've found the problem.
Just to confirm, you say the power switch is lit up. Is the small indicator light on the switch lit up when the problem occurs? It gets power from the same relay circuit that feeds the fog bulbs. If the indicator is lit when the problem occurs, then the issue is with the ground for the bulbs. There's a ground splice connector on the passenger frame rail below the coolant reservoir. The splice pack connects to the ground G102 on the frame rail. Those splice packs are known to get corroded and can result in the problem you're seeing (check the sticky post at the top of the section on electrical issues). You can clean the connector pins to solve that issue.
The other candidates are the fuses, but unlikely since it's intermittent. Fuse 32 in the passenger footwell panel provides power to the switch contacts, and fuse 6 in the underhood panel provides power to the fogs and the indicator light in the switch. The BCM controls the relay, so if all the relays and fuses check out, there might be an issue in the BCM related to the fog circuits (but unlikely).
Let us know which one it was.
Old Aug 22, 2006 | 06:54 AM
spdnman's Avatar
spdnman
I will let you know later today. Thanks for the detailed answer, much appreciated.
Old Aug 22, 2006 | 11:49 AM
spdnman's Avatar
spdnman
I tried everything and it turned out to be a bad ground. Hope it still works later. Thanks for all the help.
To Fog Lights Not Working
