Under hood light doesn't work - connected and new bulb - HELp
Old Aug 24, 2006 | 06:16 PM
SEAMOORE's Avatar
SEAMOORE
Default Under hood light doesn't work - connected and new bulb - HELp
Just bought a new to me 03 Z06 last weekend. Everything is great about the car except the under hood light doesn't work. Cleaned wiring connector and installed new bulb. Still doesn't work. Your thought and comments are appreciated. Thanks.
Old Aug 24, 2006 | 07:01 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Maybe it is a bad fuse? Not sure if there is one specifically for the underhood light?
If you unplugged, cleaned and replugged the connections and put a new bulb in I am surprised.
I seem to remember complaints on the forum about having to buy the whole underhood light from a dealer rather than just a single piece. What I am not sure of is whether the single piece in question was the light cover or the bulb? Perhaps it's not the right bulb.
You could try replacing the whole light.
Old Aug 24, 2006 | 07:25 PM
seering's Avatar
seering
Id check for power at the light to start with .. If you have power there .. then no reason to check further on the fuses.
Next step would be power at the wires entering the light fixture ..
Just a quick idea.
Old Aug 24, 2006 | 07:29 PM
mfrejek's Avatar
mfrejek
Don't just start changing parts! Used a voltmeter to determine if you are getting 12 volts to the light bulb. I am also assuming that you have the ignition set to the "on" position.
Old Aug 24, 2006 | 07:47 PM
SLPRC5's Avatar
SLPRC5
does your vanity lights and rear view mirror lights not work also? If so
Replace fuses #2 and #29 10amp...in fuse box on pass side foot weel.
Old Aug 24, 2006 | 08:20 PM
LoneStarFRC's Avatar
LoneStarFRC
If you have 12v at the chassis connector, but not at the light bulb socket itself, replace the light fixture. There is a motion sensitive switch (mercury switch?) that turns the light on when the hood is raised past a certain point.
Also, if you are not the first owner, make sure the previous owner has not installed a hood light cut-out switch. Several suppliers sell a plug-n-play harness to do this, so guys with their hoods raised at car shows didn't run down their batteries. The one I've seen have a small toggle switch installed in-line on the wire harness that leads down to the chassis connector.
The GM part number for the light assembly should be 10303617 and includes a new bulb. It is held in by a couple of pop-rivets. They will have to be drilled out and new pop-rivets installed on the new light fixture. The pop-rivets carry a GM part number, but should be readily available (much cheaper too) from any Lowes, Home Despot or auto parts store that carry pop rivets. They are .125 (1/8") and should be of the large head design. Very cheap and easy to do. The only thing is that stores don't just sell 2 pop-rivets, they only sell packs of 20 or 25, etc, so if you know anyone with a pop-rivet gun and pop-rivets you should be good to go.
Give Bob at Fichtner Chev a shout at 1-800-234-5284 if you need the light fixture. They're a forum vendor and will give you the forum pricing that's much better that your typical local dealer parts department.
HTH,
Robert
Old Aug 24, 2006 | 08:58 PM
4DRUSH's Avatar
4DRUSH
I think my light turns off after the hood is up for so long. Maybe after you changed the bulb & etc your time ran out ?
Old Aug 24, 2006 | 11:36 PM
redazz's Avatar
redazz
also if you reach thru the window and open the hood without opening the door on my 99 the light wont come on , but open the door and the light comes on .must have something to do with setting the timer to turn it off
john
Old Aug 25, 2006 | 02:11 AM
wong0580's Avatar
wong0580
If the reading lights under the rear view mirror aren't working, then it's probably fuse #2 under the passenger side floorboard.
--Ed
Old Aug 25, 2006 | 03:28 AM
DarknessC5's Avatar
DarknessC5
My connector is damaged and wont plug in so the underhood light wont come on... Does anyone know where I can get a connector?
Old Aug 25, 2006 | 07:16 AM
mfrejek's Avatar
mfrejek
This may sound like a stupid question; have you tried the Chevrolet dealership? The part number for the underhood lamp connector should be 12162192.
Old Aug 25, 2006 | 07:32 AM
SEAMOORE's Avatar
SEAMOORE
A few more comments on the under hood light problem. I can't find a specific fuse for the light so I don't think that is the problem. I'm sure it's the right bulb. Vanity lights and rear view mirror lights work.Your lights do time out after about 15 minutes and this is definately not the problem. It must be in the wiring or the fixture/switch itself. I'll bring out the volt meter this afternoon and see what I get. All your ideas and comments are certainily appreciated and any other thoughts are welcomed. Thanks.
Old Aug 25, 2006 | 08:41 AM
mfrejek's Avatar
mfrejek
There is a specific fuse for the underhood light. Like SleeperC5 already stated: it's fuse #2.
Old Aug 25, 2006 | 08:49 AM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Stealership replaced the whole unit on mine under warranty. Didn't even try to mess with it.
Old Aug 27, 2006 | 12:55 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
john
Mine did the same thing. Opened the hood without opening the door and no light, removed the key from the ignition and it came on.
Old Aug 27, 2006 | 04:01 AM
SLPRC5's Avatar
SLPRC5
The unit with bulb and lens cover is $13.00 at the dealer. Lost my lens and thought I could by the lens, WRONG had to by the entire unit.
Old Aug 27, 2006 | 04:03 AM
SLPRC5's Avatar
SLPRC5
Michael: Some folks don't get it.
To Under hood light doesn't work - connected and new bulb - HELp
Old Aug 27, 2006 | 04:06 AM
SLPRC5's Avatar
SLPRC5
That was the way mine was when I got it. No underhood light..I took the pading off and the wire had been disconnected. Guess previous owner didn't realize the light is on a "timer" to go out.
Old Aug 28, 2006 | 07:31 AM
SEAMOORE's Avatar
SEAMOORE
I found it!!!! All the fuses were fine. The connector at the harness was corroded. A little scraping and wd-40 and all is fine. Thanks for all your comments and help.
Old Aug 29, 2006 | 06:24 PM
LoneStarFRC
Glad you found it. "Uncle" Bill Curlee would be proud of you too!
