Non-premium gas
Old Aug 28, 2006 | 09:27 AM
TAGVETTE's Avatar
TAGVETTE
Default Non-premium gas
A friend of mine, and no it's not me, has run a few tanks of low-octane fuel through his vette. He is now experiencing a check engine light. The codes he's gettting is:
P0455
B0361
Any help would be appreciated.
Old Aug 28, 2006 | 09:31 AM
byte_me's Avatar
byte_me
P0455
B0361
I found this in a search...
DTC P0455
Evaporative Emission System Leak Detected
http://www.digitalcorvettes.com/foru...ad.php?t=50755
Maybe a loose gas cap would cause the leak. That's where I'd start.
The B0361 is related to the dual zone HVAC actuator...I had this code and took it in to the dealer to get the drivers side HVAC actuator replaced...is he getting any strange hot\cold difference with the AC from driver to passenger side?
Old Aug 28, 2006 | 11:21 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
this is a very controversial topic, you'd be surprised how little the difference is in some stations, talk to the tanker driver next time you him/her at a local station
Old Aug 28, 2006 | 12:04 PM
tinasue39's Avatar
tinasue39
7th Gear
Default Lower octane gas
My brother is a Corvette owner and a gas truck hauler....he uses high occtane gas and suggests that I use Chevron with Techron. I am having my third gas sensor put in under warranty. I am going to make the switch. I have been using high occtane only but guess not good enough.
Old Aug 28, 2006 | 12:53 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Gas is gas, it is the same from station to station. It is the additives they add to the mixture that makes them different from each other. They all get their gas from the same pumping stations into the truck, it is at the hub where the "additive" is added. History channel did a nice 1 hour piece on this.
I use Mobil and add my own Techron, about every 6 months, since there is no Chevron station with 300 miles of my house.
Old Aug 28, 2006 | 03:01 PM
JD's C5's Avatar
JD's C5
I agree. Saw the same program and putting Techron periodically in the tank is great. Besides that you can buy your can and whatever station you want.
Old Aug 28, 2006 | 03:28 PM
Clay Assassin's Avatar
Clay Assassin
screw991le is correct, with one exception; BP Amoco Ultimate.
It is one of a kind, if you can get it.
I believe it is only available in the Whiting, IN and Los Angeles Area.
To Non-premium gas
