Am Radio Has Noise In It
The 98 C5 radio is one of the best FM radios and the WORST AM radio I've ever had in a car. While the FM radio cassette (in the radio) and CD player (in the trunk) are static free, the AM radio sounds like something on a model T. Anyone else have this experience? I won't waste time changing out the radio cause I seldom listen to AM but once in a while I do for traffic etc. Have a convertable and antenna goes up fine and tunes in FM fine but AM stinks. Mine is a 98. BIGHANK
St. Jude Donor '06
i think this is your problem:
see post 4 and 5 in this thread!
http://forums.corvetteforum.com/show...hlight=antenna
My 98 had bad AM reception when it was new. The dealer tried to tell me it was because of my window tint. Finally they found the bad antenae connection.
But recently, my AM has been occasionally cutting out totally. Thanks to Stealthy4 for the link ---- I'm going to try tracking it down this weekend.
Steve
Steve
am radio
To clarify... I have a convertable with the REAL TELESCOPING ANTENNA not the grid on the rear windshield. FM reception is FINE.
AM reception has static except on the strongest stations. I have a 50 KW station's transmitter about 2 miles from me. That comes in FINE but other NORMAL stations have static and even generator noise. Have installed chokes in the 12Volt power lead in previous cars but have not played with this one due th the fact that you have to dissect the car to get to the radio.
St. Jude Donor '06
If you have an antenna in the windshield, you will still have the box where the rear antenna (whether it comes from the rear windshield or rear telescoping) will plug into...
Your FM should be fine because the front antenna ONLY picks up FM signal. Thats what the box is for...its to determine which antennas has the better FM signal the front or rear. Since you dont have a rear hooked up properly, your AM will be crap.
Of course this is assuming you have the two antennas system (i cant remember if converts have an antenna in the front windshield)
am antenna
I'll look in the service manual but sometimes its not precisely clear how things really hook up. Maybe I do have 2 antennas...maybe not.
am radio noise
Looked in the GM Service Manual and according to the manual if you have a convertable you have only 1 antenna. Also the diagnostic area only seems to imply a bad ground may be causes for the noise. This might be the case but think it would also cause some problems with FM and the amplifiers too. AM radio in my Montana is much better sounding than in the vette. Will check for poor grounds but don't think that is the cause.
St. Jude Donor '06
also dont count the ground out as the C5 vettes are notorious for bad grounds
Senior Member
Cruise-In V Veteran
today I celebrate 53 years of being licensed by the FCC (10-3-53) as a ham radio operator. I know a little about radio. I have an 04 CE and I have to admit that the AM reception is crappy. I am going to do a little snooping around. When you have antenna connectors they can become corroded which can affect the amount of signal the radio receives. I am going to unplug my AM antennas and clean them. Use something to "sand" but make sure the connector is cleaned so that no "sand" is left on the connector. Without doing anything at this point I think it probably is an antenna plug corrosion issue. That pictorial is really great. Thanks
am radio noise
GM Manual seems to confirm only a lead from radio to telescoping antenna mounted in the trunk... Any convertible owners around that have a similar problem?
