Window doesn't go down !! HELP !!
Old Oct 4, 2006 | 05:00 PM
Tx Ray-C5's Avatar
Tx Ray-C5
Default Window doesn't go down !! HELP !!
Okay vette guru's... my pasenger window quit working. I press the window button and all I get is a clicking sound. Do I have a bad motor or a bad regulator ?
Old Oct 4, 2006 | 06:08 PM
ScottPurlee's Avatar
ScottPurlee
Default Window motor
I'd say it's the worm gear/drive gear in the window motor that's gone bad. If so, replace the whole thing - www.rockauto.com - $74.79 w/$15.00 Core.
If I'm wrong, the window relay is $17.57 at the same place.
I changed the motor on my El Dorado - easy, about 1/2 hour.
Old Oct 4, 2006 | 07:09 PM
iaanr's Avatar
iaanr
I had the same problem in my 04Z06 a few months ago. A search on the forum suggested the problem can be fixed by holding down the "window down" button and slamming the door several times. If it doesnt work, try it again. Fixed mine and hasn't been a problem since.
Old Oct 4, 2006 | 09:56 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Button down-door slam is definately the first option. That may free it up again; for a while anyway. If that doesn't work you're looking at a new regulator in most cases.
Old Oct 5, 2006 | 12:47 AM
Tx Ray-C5's Avatar
Tx Ray-C5
Slamming the door !?!?? Are you guys serious or is this a joke ??
Old Oct 5, 2006 | 01:16 AM
mark896's Avatar
mark896
Do this, it will work:
Open the passenger door with the key in and in the 'ON' position. Repeatedly press down on the passenger window switch while banging your hand on/around the handle area (inside).
It may take you 100 times or so (couple of minutes) but they break loose almost every time.
Afterwards, make sure you roll your windows down at least twice a week. They get stuck in the 'up' position.
Mark
Old Oct 5, 2006 | 02:45 AM
Bluefire's Avatar
Bluefire
Default I agree
Open the passenger door with the key in and in the 'ON' position. Repeatedly press down on the passenger window switch while banging your hand ob/around the handle area (inside).
Mark
The "Fonzi" method worked for me too. I held the button down, and it only took ~10 good whacks. Works fine now.
Old Oct 5, 2006 | 02:31 PM
Z06ufgrad2002
Yes, it's the same principal as slamming the door. It jars the motor and gets it working again.
Old Oct 5, 2006 | 02:50 PM
mark896's Avatar
mark896
Slamming wouldn'td do it for me. I guess the car wanted some extra special attention..
Old Oct 5, 2006 | 10:46 PM
Tx Ray-C5's Avatar
Tx Ray-C5
news FLASH !! I did just as you guys told me..... pressing the switch and beating on the inside door panel..... after about 35 or 40 hits, the glass went down and now works fine ! Who would've thought !
Thanks for the help !!
Old Oct 5, 2006 | 11:44 PM
debmwb's Avatar
debmwb
See...
new motor - $75
banging on the door - priceless!!
Old Oct 6, 2006 | 11:03 AM
Tx Ray-C5's Avatar
Tx Ray-C5
Originally Posted by debmwb
See...
new motor - $75
Old Oct 6, 2006 | 11:27 AM
Bajapit's Avatar
Bajapit
Kinda reminds me of the "EMMIT FIX", from Andy Griffith Show. Where Emmit would Bang on a toaster and It would start working. Is this in the ZO-6 or all C-5's?
Old Oct 6, 2006 | 11:31 AM
mark896's Avatar
mark896
I believe it's for all C5's..
Old Oct 6, 2006 | 12:49 PM
Tx Ray-C5's Avatar
Tx Ray-C5
I wonder if this method would work on my wifes Tahoe.... the passenger side window won't go down. All I hear is a ckicking sound when I push on the window button ...
To Window doesn't go down !! HELP !!
