MAF sizes and features question
Old Oct 26, 2006 | 09:36 PM
muncie21's Avatar
muncie21
Default MAF sizes and features question
**Update: Pictures of the MAF and measurements have been added below. **
So here's how I 'thought' MAF sizes/features went.
97-01 78mm MAF with 3 wire hook-up
02-04 85mm MAF with 5 wire hook-up
So...I picked up a spare 3-wire MAF I have in the garage and decided to use my new digital calipers to test it.
Being that's it's three-wire I should come up with 78mm somewhere..right?
Inside diameter is 85mm (3.3"), outside is 90mm (3.5")
Wall thickness of the MAF is 2.5mm, which makes sense, as the OD is 5mm larger than the ID.
comments?
Old Oct 28, 2006 | 09:11 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Old Oct 28, 2006 | 12:14 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
There were actually three versions:
97-00 75mm MAF with 3 wire hook-up
01-04 85mm MAF with 5 wire hook-up
02-04 85mm MAF with 5 wire hook-up & no screen (Z06 only)
I can't explain what you measured.
Old Oct 28, 2006 | 07:08 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default MAF Question
Will the 01-04 85mm with 5 wire hook-up work on a 97-00 car which called for a 75mm unit? Is the plug the same?
Old Oct 28, 2006 | 08:31 PM
muncie21's Avatar
muncie21
The plug is different (5-wire vs. 3 wire) and obviously the diameter is different.
The good news is that they make plug adapters for the MAF/IAT and other adapters for the air bridge.
Old Oct 28, 2006 | 08:33 PM
fdxpilot's Avatar
fdxpilot
Well, one has 5 wires, and one has 3, so no, they are not the same. 01 and up have an integral IAT sensor, hence the extra wires.
Old Oct 28, 2006 | 09:31 PM
muncie21's Avatar
muncie21
Here are some pictures for the 'show me' crowd out there.
What we've got here is a 3-wire MAF.
So...being a 3-wire job, it should measure 78mm right?
hmmm, not here. OD is 90.xxmm
OK, so what about the ID....
Uhh, nope...measures right at 85mm
Guys I gotta be missing something here....tell me what it is!
Old Oct 30, 2006 | 01:26 AM
muncie21's Avatar
muncie21
No ideas??
Old Oct 30, 2006 | 01:39 AM
EHS's Avatar
EHS
In addition to your clocks, have you set back your calipers?
Old Oct 30, 2006 | 07:13 AM
cenzo's Avatar
cenzo
Possibly an aftermarket 85mm MAF sensor for a '97-'00?
Old Oct 30, 2006 | 07:55 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Very interesting. Do you have a newer true 85mm MAF to compare with? Also, do you have a metric ruler you can measure with just to confirm that your digital caliper is measuring correctly.
I have to admit, I'm confused. I have always heard that the 1997-2000 MAF is a 3" and the 2001+ is a 3.5" I was about to upgrade to a newer MAF, but now I'm not so sure it's needed.
Old Oct 30, 2006 | 10:07 AM
muncie21's Avatar
muncie21
I verified the caliper accuracy with a measuring tape.
For those that are metric/SAE challenged like myself here's the conversions:
78mm=3.07"
85mm=3.35"
90mm=3.54"
Old Oct 30, 2006 | 11:10 AM
EHS's Avatar
EHS
78mm=3.07"
85mm=3.35"
90mm=3.54"
Old Oct 30, 2006 | 02:22 PM
torchredfrc's Avatar
torchredfrc
Old Oct 30, 2006 | 04:50 PM
EHS's Avatar
EHS
No ideas??
I just looked at your measurement picture again.
Are you measuring the narrowest part of the I.D.?
Old Oct 30, 2006 | 05:05 PM
Dirty Howie's Avatar
Dirty Howie
Maybe your filter is allowing dirt to pass. Then after billions of cubic feet of dirty air passing thru the TB at high speeds there has been a slow attrition of the ID.
Now this is just MAYBE.......
DH
Old Oct 30, 2006 | 05:44 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
http://paceperformance.com/index.asp...arch=CAS108100
To MAF sizes and features question
Old Oct 30, 2006 | 06:20 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Now that you have me wondering,Yesterday I bought a 01 ZO6 mass air (5 wire plug)from auto zone for my 97.On the screen side outside to outside it is 98mm,inside is close to 94mm.Other side, outside is 93.50mm,inside is 88.90mm .....................Paul
Old Oct 30, 2006 | 06:44 PM
6SPD98's Avatar
6SPD98
Default Maf Sensor
Thank You........I appreciate it.
Old Oct 30, 2006 | 06:57 PM
RED99's Avatar
RED99
You are measuring at the wrong place in the ID. You have to measure the smallest diameter inside the MAF.
1mm = .03937"
