Will Header Wrap Reduce Noise?
Old Oct 29, 2006 | 10:57 AM
Casem1's Avatar
Casem1
Default Will Header Wrap Reduce Noise?
Simple question: With headers my valvetrain noise is, of course, much more noticeable. Will header wrap reduce that noise?
Please save your 'header wrap will destroy your headers' talk. I don't care. LG already reduced the price of their ill-fitting system by $400 since I bought it, so I don't care. If anything, destroyed headers will give me a reason to buy a neew set of kooks.
Anyone that has wrapped their headers, did the noise go down???
Old Oct 29, 2006 | 01:45 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need to look into getting one of those insulation kits (sound deadning) from one of the supporting vendors or else where.
Wrap will keep the heat in, won't due much to quiet down the interior noise levels.
Old Oct 29, 2006 | 02:01 PM
ALLEGRO's Avatar
ALLEGRO
At best it would reduce the highest of frequencies. Overall it will not make much difference. I too suggest a sound-deadening project.
Old Oct 29, 2006 | 04:38 PM
Charley Hoyt's Avatar
Charley Hoyt
Why are you getting more valvetrain noise? I didn't have this issue when I installed my headers. Is this a common problem?
Old Oct 29, 2006 | 04:52 PM
Casem1's Avatar
Casem1
From what I have heard it is pretty common. It is simply due to the fact that the headers have such a thin wall (I was actually surprised how thin) whereas the stockers are thick walled iron. A few guys have mentioned wanting to put header wrap on their GTO's and Firebird's because they heard it helps the noise. Neither have done it yet, and I wanted some input from someone who actually knows (has heard a difference, not just someone who doesn't think it will work) before I drop $100 on a roll of 2" wrap.
I say 'valvetrain noise' but I imagine the majority of the sound actually comes from combustion itself.
Old Oct 29, 2006 | 07:27 PM
Mike Mercury's Avatar
Mike Mercury
Just used header wrap on wifes 1973 - solely for cockpit over-heating issues. But it did reduce the tinny tapping noises of the engine. Not a helluva lot... but enough to notice.
http://forums.corvetteforum.com/show....php?t=1477433
Old Oct 29, 2006 | 09:45 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
A good reason to NOT wrap your headers; it creates excessive tube wall temperatures, ultimately shortening the live of the tubes.
You may not realize it, but every time hot exhaust gases flow through the header tubes, microscopic particles of the steel are released into the exhaust stream. The higher the temperature, the higher rate of material loss.
Wrapping the header tubes (closer to the head the more dramatic the effects of course) will accelerate and thin the tubes prematurely.
Stainless is more durable than mild steel, but if you plan on keeping the car for the next several years, I would not recommend wrapping the headers.
Old Oct 29, 2006 | 09:53 PM
triblk6spd's Avatar
triblk6spd
i think in his 1st post he said; "save it." great you just wasted all of our time with your nonsense.
Old Oct 29, 2006 | 10:14 PM
Dan_the_C5_Man
What part of my response was "nonsense"? The author wasn't my only target. Let me edumacate you. http://www.centuryperformance.com/heatwraps.asp
Old Oct 29, 2006 | 11:14 PM
Sawbladz's Avatar
Sawbladz
The point was more that he doesnt care about the effects to the header. Not wheter or not you were right.
Old Oct 29, 2006 | 11:48 PM
Dan_the_C5_Man
Oh, I understood; don't feel obligated to defend posts like "great you just wasted all of our time with your nonsense."
Old Oct 30, 2006 | 10:28 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Wrap will eat at the headers! The wrap will not make a big difference if any at all! I tried it when I had my '90 and it didn't give me any good results!
Thanks,Matt
Old Oct 30, 2006 | 01:11 PM
EBM_Z06's Avatar
EBM_Z06
If header wrap won´t quite down the valvetrain noise is there anything else one could do ? There has got to be something ? I can´t belive all you guys with headers are dealing with these increased valvetrain noises...
Do some headers have thicker tube walls than others ?
I´d love to install headers on my Z06 but definitely won´t deal with the valvetrain noise again... I remember this back from my fbody days and really hated that noise caused by the thin walls of the tubes....
Old Oct 30, 2006 | 08:51 PM
01vetter's Avatar
01vetter
Also interested in if this is common to all headers. How bad is it from inside the car? I haven't seen many complaints.
Old Nov 2, 2006 | 12:26 AM
triblk6spd's Avatar
triblk6spd
settle down beavis! i was making a joke. you know a joke, like to be funny. and no you did not understand my origional post or you would not be crying about it.
To Will Header Wrap Reduce Noise?
