Help... gas gauge died
Old Nov 6, 2006 | 10:55 PM
adown's Avatar
adown
Default Help... gas gauge died
I was driving down the road with just under 1/2 tank and all of a sudden my gas gauge died and the check gauges light illuminated. Has anybody else had this problem? Where does the wire plug into the tank and where does it come from. It's like its open somewhere. Or is there a fuse. It should work on ground I thought. When I turn on the key it works for the gauge check. It goes all the way up then back down. Any help would be appreciated. Thanks, adown
Old Nov 6, 2006 | 11:33 PM
R Devil's Avatar
R Devil
Common issue on C5's. Sometimes easy to fix. Do a search on Fuel Gauge for a start.
Old Nov 7, 2006 | 02:36 AM
PierEagle's Avatar
PierEagle
Also do a search on Techron You should find many, many stories like yours and a ton of suggestions.
Cheers
Old Nov 7, 2006 | 11:35 AM
W Muller's Avatar
W Muller
Your right tank fuel level sender is probably dirty. It’s common problem. Techron helps clean it. The way most cars work the sender is submerged in gasoline almost all the time. Your Corvette has two gas tanks. The way the Corvette fuel system is plumbed the right sender is only submerged in gasoline until the fuel level goes below ½ tank. Then the right tank is empty and the sender is in gas fumes only. What little gas is I there splashes on the sender and evaporates leaving the solids from the gas. If you are mechanically inclined, the sender is not too hard to clean. If you clean it you will see the problem. The resister will have some build up on it causing some of the windings to short out and cause an incorrect output. Do a search on fuel sender and there should be a procedure on how to get to it. A pencil eraser and some contact cleaner work well to clean it. If you use techron make sure you have at least ¾ of a tank of gas or you won’t get any techron into the right tank. My experience is that techron works somewhat but cleaning really works.
Old Nov 7, 2006 | 03:01 PM
EHS's Avatar
EHS
1. Run a couple of tankfuls of Techron through it, and use the best premium you can find.
2. Go to the dealer, and have them give you the latest PCM software update (emphasis on give). A good dealer will reflash the PCM for you for free.
#2 is important, and there is a Tech Bulletin out on it. It reprograms the sensitivity of the sending unit.
Old Nov 7, 2006 | 10:28 PM
adown's Avatar
adown
Thanks guys. i'm out of town and stuck with dial up. Its all I can do to get this page open. I'd never make it through a search. Thanks again, adown
Old Nov 8, 2006 | 11:56 AM
bighank's Avatar
bighank
Default same problem
Same symptoms. For about a week it read 7/8 full when topped off. Then yesterday while driving SUDDENLY went to ZERO and LOW FUEL appeared on the DIC.
Had one of these suckers replaced a few years ago under warranty.
GM Manual says there are 2 senders working in conjunction with each other so I didn't want to dissect the WRONG sender. Put Techron in and will see if I can get away without a day long job taking tanks down etc,
It was down about 5 gallons and it went to Zero again. Filed up with Chevron supreme with techron. Now when super full reads midway between 15/16 and FULL. Used to read SUPERFULL (above the full mark) Again which sender is likely the culprit.
Do I have to go thru the process of removing a tank and cleaning the sender. The GM manual procedure looks very nasty.
Thanks BIGHANK
Old Nov 19, 2006 | 12:54 PM
bighank's Avatar
bighank
Default Gas Guage goes to Zero
Added a can of SEAFOAM to the tank before topping off with Chevron.
Guage still NOT at FULL. BIGHANK
Old Nov 19, 2006 | 05:06 PM
dads01dream's Avatar
dads01dream
Just a thought, be sure NOT to do the PCM software upgrade if your car was re-tuned for any performance mods..... May end up losing your tuning?
Where can you get "SEA FOAM"??
Old Nov 19, 2006 | 05:14 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Where to get "Seafoam"??? Never heard of it before this post...maybe its me; is it a cleaner of sorts? Appreciate the help and thanks.
Joe
Old Nov 19, 2006 | 05:27 PM
nuke61's Avatar
nuke61
Seafoam is a fuel system top-end engine cleaner, much like GM's own "Top End Engine Cleaner", but a bit lower in cost. Where I live, NAPA and Pep-Boys stores carry it.
The cleaning of the senders may not happen right away. It took my car a few tankfuls before the sender worked properly and read the correct level. The same process of using Techron and running a few tanks of gas, making sure to TOP UP to get both senders covered, worked for my car and my wife's Corvette. Good luck.
Old Nov 20, 2006 | 12:37 AM
dads01dream
Hmmmm, so if "Sea foam" works like Techtron..... which is cheaper and I'll take that route?
Old Nov 20, 2006 | 03:52 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Joe
Advance Auto has it where I live. The stuff is great, fuel system cleaner, fuel stabilizer and top end cleaner. I believe you can even throw it in your crankcase... I haven't done that though.
Old Nov 20, 2006 | 02:09 PM
bighank's Avatar
bighank
Default Seafoam
Got it at Autozone in MD. Think it was $5.99 for a 12 oz can. You can let some go into your intake but I dumped it all into the gas tank. BIGHANK
Old Nov 20, 2006 | 08:53 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
you sure you didnt run out of gas?
To Help... gas gauge died
