Superchips foiled again...again and again!
Old Sep 28, 2001 | 06:43 PM
vstella's Avatar
vstella
Default Superchips foiled again...again and again!
Talk about frustration! 3 Times Superchips programmed my PCM.It just WILL NOT shift at WOT :mad
With all due respect to their professional attitude and eagerness to please.
The fact of the matter is that the 2001 Corvette LS1 has them stumped.It is very disheartning to make plans ,buy parts,spend time and money and to believe that you have made the "right choce" in vendors and then this :nonod:: :confused: :confused: :confused:
I have already ordered the Powerloader from Matt and Richard at Exit 28 Motorsports.
It will be 4-5 weeks befor I will have the Powerloader.I'll just wait!
I feel like :boxing: Oh well . Boys and their Toys......
Old Sep 28, 2001 | 06:48 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Superchips foiled again...again and again! (vstella)
Have you thought about giving Ed a call?
http://www.fastchip.com
He can usually over night your PCM back to you so you're looking at only a couple of days of down time.
-Jeremy
Old Sep 28, 2001 | 07:08 PM
vstella's Avatar
vstella
Godspeed.....Ed Wright might be one answer. He's got a great reputation, and it may come to that
if the powerloader does'nt settle the problem. I just don't want to take out the PCM again.
The first time the strap that held the PCM cracked. I really don't have even two days at this point to give up my daily driver.
The car runs great otherwise. Just not at WOT.
Old Sep 28, 2001 | 07:22 PM
Godspeed's Avatar
Godspeed
Senior Member
Find a local C5 buddy who has a similiar vette that is not a daily driver. Use his PCM while yours is down for two days being programmed.
Ed does fantastic work - he tuned my SS. :D
Old Sep 28, 2001 | 08:18 PM
vstella's Avatar
vstella
Default Re: Superchips foiled again...again and again! (Buckmaster)
It's a shame that a vendor who is "supposed" to be reliable and presents a state of
the technology product can't deliver the product they advertise.
I'm sure they have products that do work, and many satisfied customers.
This one doesn't!and I'm not one of them! 'Enough said. :( :(
Old Sep 28, 2001 | 08:45 PM
goldman's Avatar
goldman
I also had problems with Superchips, but I returned mine after their second programing attempt, since mine also "crashed" the PCM during both "un-installs" (requiring the PCM to be re-flashed)... Didn't you & I discuss this previously ??? Sorry it didn't work out for you.... But you'll lOVE the Powerloader!!! MUCH better program & absolutely NO problems !!!
Here's an earlier post where I compared all 3 tuners... http://forums.corvetteforum.com/zerothread?id=133505
Old Sep 28, 2001 | 08:49 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
That sucks! :(
Old Sep 28, 2001 | 10:14 PM
kendawg's Avatar
kendawg
my 2001 coupe had 2 A4 trannys replaced[fried 2/3 clutch packs] because it wouldnt shift at W.O.T..tookem 3 tries to figuer out it was a faulty speed sensor/they said it had a weak signal at W.O.T
could it be that the sensor failed at the same time you got your pcm reprogramed?
[Modified by kendawg, 3:34 PM 9/29/2001]
Old Sep 28, 2001 | 10:47 PM
vstella's Avatar
vstella
Default Re: Superchips foiled again...again and again! (kendawg)
Kendawg...Could be the speed sensor ,buy why only at WOT.
Does the transmission descriminate on throttle pressure!
Old Sep 29, 2001 | 10:15 AM
WildWolf's Avatar
WildWolf
Vince- will you be able to run October 14? No WOT is a small problem for running the 1/4.
Old Sep 29, 2001 | 10:27 AM
vstella's Avatar
vstella
Default Re: Superchips foiled again...again and again! (WildWolf)
Josh...Im doing everthing I can to make it. I want to run good.But there is no sense if I don't have the car running right.
What's the point.
If nothing else I will be a spectator and see all my CF friends.
Old Sep 29, 2001 | 12:30 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
What's the point.
sorry to hear Vince....hopefully it'll be corrected by then....if not, we'll see you there :cheers:
Old Sep 29, 2001 | 05:07 PM
MDL-01C5's Avatar
MDL-01C5
Dude, it's time to pull out the "I'm-going-to-be-an-arsehole-bat"
They will fix it;) :cheers: :flag
Old Sep 29, 2001 | 10:38 PM
vstella's Avatar
vstella
Good news here ! I tried something with the computer and I got it to shift in WOT.
The program is far from perfect, but it does now shift at 6200. Redline is 6400. Shifts are firm and definate.
It won't work in 3.... only drive. It won't upshift at WOT manually either but it does shift at WOT in drive.
Hopefully the car will learn my shifts and stay in the computer. I reflashed to stock and then loaded the program again.
Superchips still needs to figure how to perfect this thing. I'm not thrilled ,but I do feel better.:yesnod:
I'm still sending it back. :yesnod:
Old Sep 29, 2001 | 11:28 PM
TLewis4095's Avatar
TLewis4095
What a relief! Drive is just fine...just gotta get used to it.
Old Sep 30, 2001 | 12:34 AM
MelloYellow's Avatar
MelloYellow
Things could be worse.. I'd def move on to another programmer.. Anyone with a 2001 Auto should avoid SC I guess.
I'll be switching to MMS for my programming shortly. Will get to see their critique of the SC prog, but I haven't had any issues. Just want my tuner 100% behind my new setup.
Old Sep 30, 2001 | 09:57 AM
vstella's Avatar
vstella
Default Re: Superchips foiled again...again and again! (MelloYellow)
Mello Yellow, I ordered the Powerloader. Hopefully it fill in the blanks in the SC program.
To Superchips foiled again...again and again!
