When is it time to get new tires ?
Old 02-27-2007, 10:01 PM
hotrod03
hotrod03's Avatar
Default When is it time to get new tires ?
How much tread depth do I need before I need to relace the rear tires. I have 28k on them, the front tires look fine, but the rear tires have only about 1/8" of tread depth. I priced a set of Mich. azp for $1200.00 for the four. Is that a good buy?I do not think it would be right to just replace the rear tires only?
Old 02-27-2007, 10:05 PM
Illini82
Illini82's Avatar
St. Jude Donor '07
1/8" isn't much, it's probably time to replace them
Blown 346
Blown 346's Avatar
$1200 for all 4 is a deal. I forgot the exact depth, but a 1/8 th of an inch is pretty low.
Old 02-27-2007, 10:06 PM
hotrod03
hotrod03's Avatar
I think your right
Old 02-27-2007, 10:08 PM
jeanlucpicard
jeanlucpicard's Avatar
Your car, your life, your choice.
Typically, the annual state inspection will not pass tires that have less than about 1/32" of tread on them - in Texas at least.
I run Firehawks and get about 25,000 before swapping them out at $1600 a set. When you are moving along at 140mph plus, good rubber is a must have. Also, if a tire shreds at 75mph you can trash a fender or more on your car.
Best of luck.
Old 02-28-2007, 12:04 AM
USA C5
USA C5's Avatar
Default It's Time When
Don't go below 5/32". Consider replacing around 5/32" or 4/32" as EMT's will hydroplane at that tread depth. In May of 2006 my EMTs had 22,000 miles on them and were down to ~ 3/32" to 5/32". I replaced them w/ Michelin Pilot Sport A/S ZP’s (ZP= Zero Pressure or Run Flat). They were $235.00 and $335.00 respectively from the Tire Rack. The same EMT was $100.00 more per tire! TR can refer you to a local installer in your area. These Michelin tires are much quieter and have a better overall tread ware, traction and temp rating than the EMTs.
Michelin (UTQG) Rating = 400 AA A, EMTs (UTQG) Rating = 300 AA A
Old 02-28-2007, 12:13 AM
nonsuchpro
nonsuchpro's Avatar
Just like Mario Andretti says.... stick a penny upside down in the tread and if you can see the top of Abe Lincoln's head, it's time to change the tires
Old 02-28-2007, 01:00 PM
dbirdz06
dbirdz06's Avatar
Replace them before they look like this:
I'd say anything beyond the wear indicators is pushing it. They're there for a reason.
Old 02-28-2007, 04:30 PM
Z28TOZO6
Support Corvetteforum!
Z28TOZO6's Avatar
i didnt know they made retreads for vettes!
Old 02-28-2007, 04:34 PM
B-ras
B-ras's Avatar
How much tread depth do I need before I need to relace the rear tires. I have 28k on them, the front tires look fine, but the rear tires have only about 1/8" of tread depth. I priced a set of Mich. azp for $1200.00 for the four. Is that a good buy? I do not think it would be right to just replace the rear tires only?
Do you mean in general or using a mismatched set front/rear. I would avoid the latter, but I typically go through 2 sets of rear for every set of front.
Old 02-28-2007, 05:27 PM
Point & Shoot
Point & Shoot's Avatar
Check Discount Tire Direct for the Michelin runflats. They typically run rebates - I got the set for $1,050 - free shipping.
Old 02-28-2007, 11:08 PM
hotrod03
hotrod03's Avatar
That pretty much says it all, I like it!
Old 02-28-2007, 11:40 PM
zo6chik
zo6chik's Avatar
the wear bars are set at 2/32 of an inch on all tires. 1/8 inch (as stated above) is 4/32, normally it would be time to replace tires at 4/32, on the other hand my vette never sees rain so im not that concerned with wet traction. i run my tires down to legal limit(2/32). also do not judge/buy a tire based on tread wear rating. that number is given to the tire by the company that manufactured the tire, they can put any number they want on it. (its not the same rating throughout the industry) and yes i do work at a tire shop.
Old 03-01-2007, 12:12 AM
superjet701k
superjet701k's Avatar
all these improper fractions are making me
Old 03-01-2007, 01:42 PM
zTrek
zTrek's Avatar
Using a penny, put the penny into a tread groove with Lincoln's head upside down. If you can see all of Lincoln's head, it's time to replace.
Old 03-01-2007, 02:36 PM
TUF-NUF
TUF-NUF's Avatar
Location: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default when to replace???
as soon as you realize that you're running on runflats!!!!!
Old 03-02-2007, 05:39 PM
hotrod03
hotrod03's Avatar
Just bought a set of Kumho "y" rated tires, non run flats and got the Continintal Conticomfort flat tire kit for $69.00. Small compressor and sealant. I am ready for some peace and QUITE!
To When is it time to get new tires ?
Quick Reply: When is it time to get new tires ?
