Pilot bearing ?
Old Mar 7, 2007 | 09:43 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Pilot bearing ?
I have an 97 C5 w/auto trans,When I took out the drive shaft and took off the flywheel there was no pilot bearing in the crank(original motor).I'm putting in a different motor and it has a pilot bearing but I took it out because I thought it was for manuals only.So do I need to put it back in,Or can I leave it out...............Paul
Old Mar 7, 2007 | 10:32 AM
Julian@Cartek's Avatar
Julian@Cartek
You can go either way, we leave the pilot bearing in to give the shaft more stability.
Old Mar 7, 2007 | 11:53 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Cool,Thanks.I went and picked one up at AutoZone,But It does not have the needle bearings,That doesn't matter...right? It all spins together anyway on an auto,I don't know how a manual is.......Paul
Old Mar 7, 2007 | 12:24 PM
Julian@Cartek
Because your car is an automatic it will be fine, but if it was a manual then it will be a different story.
Old Mar 7, 2007 | 01:49 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Yea,I put it back in,Good thing its an auto .Like you said,More stability. .Thank you.................Paul
Old Mar 8, 2007 | 09:50 AM
Julian@Cartek
Ya welcome glad to help out.
To Pilot bearing ?
