Wheel lug nut torque spec?
Oct 12, 2001 | 03:27 PM
I need to remove my rear wheels this weekend. Does anyone know what the torque specification is for the lug nuts? Are the front ones the same?
Oct 12, 2001 | 03:35 PM
Re: Wheel lug nut torque spec? (1stC5)
110 is what I was told all the way around.
Oct 12, 2001 | 03:49 PM
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Re: Wheel lug nut torque spec? (cosmosm3)
30 - 60 - 100....I personally do the last round to 96 ft-lbs. make sure to use the "star pattern" :cheers:
Oct 12, 2001 | 04:07 PM
Re: Wheel lug nut torque spec? (Mean Green 2000)
Same here 30-60-100 in a star patteren. :seeya
Oct 12, 2001 | 05:57 PM
Re: Wheel lug nut torque spec? (zoneblock)
:yesnod: 100 ft-lbs. is the correct value. I did some pretty heavy checking since my 2001 factory Helm's manual gives two different values (each on a different page). I also recommend using a progressive approach like the 30-60-100 recommend above.
Oct 13, 2001 | 10:07 AM
cosmosm3 check your owners manual.
100 ft/lbs @ 30-60-100 in a star pattern
Oct 13, 2001 | 12:41 PM
Re: Wheel lug nut torque spec? (MySea5)
FWIW, I have seen posts to the effect that you run less chance of rotor warping with 90 ft/lbs as the final value. So I use 30 - 60 - 90 with no problems.
Oct 13, 2001 | 07:11 PM
100ftlbs
Oct 14, 2001 | 01:15 AM
I had rotor warping on my '98. After the dealer graciously fixed the problem, I retorqued to 90 ft/lbs and had no problem. I now have an 01. Is the warping problem still there on this model year? :flag
2001 ,
98 ,
c5 ,
corvette ,
installation ,
lug ,
nut ,
spec ,
specs ,
torque ,
wheel
