Michelin Pilot Sport run flats; air pressure?
Just got a good deal from a buddy on a set of the Michelins.
Goodyear runcraps are gone! Good riddance.
The tire installer dudes put 35 psi in there. Should I stick with 30 cold?
I was running 38 psi after they heated up, seems a little high to me?
Any Michelin guys help me out here.
Bill
Bill
CorvetteBrent (09-20-2018)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
28 in the rear and 30 in the fronts (COLD)
That give the best handling and tread wear!
BC
BC
pilot sports
Pilot Sports can either be had in NONrunflat or ZP(Zero Pressure) RUNFLATS. Michelin told me to run 3 to 5 # over the suggested 30PSI and to check the tread wear across the tread to make sure that it isnt wearing in the middle or on the edges. Have only had em about 5 months but feel like I'm driving a new vette. Spend the extra few bucks and buy the RUNFLATS (ZP) They have a built in road hazard warranty good for FREE REPLACEMENT including MOUNTING AND BALANCING for 2 years or 50% of tread remaining. After that they are prorated. No need to purchase any other coverage when buying the ZP tires. BIGHANK
Thanks for the Info Big Hank
I have run 30 in front and rear - a C5 is too light for 30 in the rear, never mind 35 on the ZPs. My centers wore on the rears with plenty of front left. Bill Curlee is right - 28 in the rear seems fine for the street
They are great tires, BTW.
St. Jude Donor '11
I checked with Discount tire and Michelin no longer uses the ZP for the run flats. They now use RF. The fronts are 245/45ZR17 95YRF DIR (Discount tire stock # 34182) and the rears are 275/40ZR-18 99YRF DIR (Discount tire stock # 34204. Mail order price is $226 each for the fronts and $318 each for the rears with free shipping.
Michelin PS A/S ZP from Discounttiredirect
I purchased the Michelin Pilot Sport ZPs from Discounttiredirect. Go to the Michelin website and there you can download the warranty information. It's about 16 pages and I think its and Adobe pdf file.
Somewhere after the first few pages the warranty descibes the Pilot Sport ZP warranty. It is as i have posted above. Get the toll free number and CALL Michelin if you have any questions about the warranty or anything else. I did all of this BEFORE I purchased the tires.
About 6 months ago the total was $1108 for front and rear. No extra charge for shipping.
THEN shop around for an installer. I actually got a BETTER PRICE for ROAD FORCE BALANCING from my GM DEALER. I was AMAZED.!
They wanted $70 plus $5 per tire for DISPOSAL FEE. I didn't want the hassle of dumping the old ones in a dumpster so I paid $90. The recommended installers form both Tirerack and Discounttiredirect(which you can access on their websites) were MUCH HIGHER. Extra for Runflat, Extra for TPS, Etc. Chech around and see what you can find locally. Took about one week to get the tires via standard UPS ground shipping and they arrived in excellent condition. Were very fresh too.
You can check this by looking at the DOT code molded into each tire.
Good luck! You will be pleasantly surprised by the difference in the performance. BIGHANK
Micheling pilot sport runflats all season....pressure?
That tire is what I have and On Star said they were low in pressure, so I put in air up to 30. Now the tire sensor says that they are over pressured. I let air out until it reached 28 and the sensor still says they are too high in pressure. Whats going on?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
Bill
Bill
It takes several minutes fo the ‘new’ pressure to be read by the system, that could be why you’re still seeing the message after you have made the pressure adjustment. If it hasn’t changed after several miles, then ya, there could be some other issue.
if whomever did the tires did not get the rims back on the same side (and did not retrain the sensors), it can drive you crazy - you’ll adjust the wrong tire..
