Who's running 12.1 to 1 compression on 93 BP/Amoco Unleaded?
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Thinking of going with a MAX EFFORT 402 LS2 with 225 Trick Flow Heads that I ran across and she makes around 12.1 to 1 compression, and would swap this into my 02 Z06, that will be driven primarily on the street (with ocassional romp at the track)!
I figured with a proper tune this should not be a probelm with 93 octane and of course if i go racing I will go with 100 unleaded, etc.
Who is running a similar set-up and this is also with a smaller cam 236/240, on a 112 lsa (if that matters or not) and do you think this a not a problem with 93 octane (AMOCO/BP FUEL).
St. Jude Donor '06
I am double checking but I believe it is 9.1 to 1, but will reconfirm. Figured as long as timing was pulled a bit in the right areas on a prof. tune I would be good to go but what are your thoughts? :drive:
PHIL, what was you dynamic compression on the motor your 12:1 to 1 motor that you ran?
Also, PHIL, will my Kooks 1 3/4 headers attached to my stock LS6 motor in my C5 Z06 right now bolt right up to the 402 LS2 Longblock I am thinking of buying and dropping in?
I am double checking but I believe it is 9 or 9.1, but will reconfirm. Figured as long as timing was pulled a bit in the right areas on a prof. tune I would be good to go but what are your thoughts? :drive:
~9.0:1 was the DCR on my motor. The kooks headers will work fine. I didn't back any timing out of my motor.
Phil
Depends on the tune I guess.
My engine is 11.8:1 with a 8.4 DCR and I run fine on BP 92 octane. I have a 238 242 114 cam. I softened my DCR due to the 92 which sucks since I'm only one state away from you, but all IA BP's are 92 instead of 93 octane.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I ran 12:1 SCR and 8.8:1 DCR in my 403 L92 setup. We could only run 24 degrees of timing before KR. We lowered the SCR and DCR with a smaller cam and change dropped the SCR with larger chambered heads and were able to add 5 degrees of timing and picked up a bunch of RWHP and RWT.
My $.02
My $.02
Well to an extent. You don't want the quench area to large. It's better to take compression away from the chamber if possible or play with cam size and timing to lower the DCR.
