Airbag Removal.. Need Help.
Old Apr 19, 2007 | 09:29 AM
123sugey's Avatar
123sugey
Dig
Default Airbag Removal.. Need Help.
I Need To Remove The Passenger Side Airbag. How Is This Done ?
Old Apr 19, 2007 | 03:00 PM
123sugey's Avatar
123sugey
Dig
i thought this would be an easy question for someone to answer
help.......
thanks
Old Apr 19, 2007 | 05:06 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Pull the fuse for the airbags and disconnect the battery
remove the glove box
remove the dash pad
remove the 4 nuts that hold the airbag to the aluminum bracket.
Old Apr 20, 2007 | 09:24 AM
123sugey's Avatar
123sugey
Dig
is there any special tool or anything i need to know to remove the dash pad befor i start ?
Old Apr 20, 2007 | 05:22 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It's a pretty straight forward job, If I remember right all you will need is a 10mm socket, 9/32 socket some extensions and a small screwdriver.
Old Apr 20, 2007 | 05:47 PM
Christine2000's Avatar
Christine2000
Make sure to mark all the fastner locations on the pad and the bag bracket. The holes are slotted and it will save you a lot time adjusting alignment when you put it back together.
Old Apr 20, 2007 | 06:49 PM
123sugey's Avatar
123sugey
Dig
thanks for your help
Old Apr 20, 2007 | 07:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Better read the manuals on how to disable the air-bag system first otherwise you risk it going off and deploying.
Old Apr 20, 2007 | 11:39 PM
123sugey's Avatar
123sugey
Dig
thanks
Old Apr 22, 2007 | 11:59 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Mine weren't slotted on my 04 Coupe
Old Apr 22, 2007 | 06:27 PM
123sugey's Avatar
123sugey
Dig
Thanks for evryones input
Old Jan 31, 2008 | 10:15 PM
Higgs Boson's Avatar
Higgs Boson
What resistance is the stock plug looking for?
To Airbag Removal.. Need Help.
