How much should the labor be to change shocks?
Mike Raines (02-19-2018)
Mike Raines (02-20-2018)
Just my $0.02 - but I've done shocks on C4's, a C5 and a C6, and I don't think 1/2 hour per shock is reasonable!!! It takes a few minutes just to jack up the car, and remove the wheel, and get the car on a jack stand then you have to undo the shock mounting nuts, and remove the shock. If the old shock still has a gas charge in it - removal is NOT a 2 minute job !!! Once you get the old shock out - you need to compress the piston on the new shock, and tie it in place (I use this steel "mechanics wire"), then fit the new shock into the lower mount, and cut the wire while "guiding the shock rod into place on the upper mount. Then you tighten the mounting nuts, and replace the wheel, and lower the car. On the rears - sometimes you need to pull the rear tie rod end for decent access. On the C6 - I ended up pulling three of the four upper control arm mounting bolts, to make the shock removal easier.
For a Do It To-Yourselfer - figure at least 60 minutes per corner - ninety minutes is probably safer. Heck - it normally takes me at least 5 minutes just to get the piston rod compressed (I use a floor jack to push the shock up against a heavy work bench top) and tied into position with wire....
with Black Friday just about here, the best starter set for handling is the C6 Z51 Sway bats with Z06 shocks. I got them. Loved them. Very acute response from the sways. I wasn’t impressed with the Z shocks but for 300 your not gonna get a Aldan American performance from them. But you won’t bottom out and that’s a definite upgrade compared to trash OEM. You’ll pay less with the Black Friday sale.
Cultrag performance, Gene already started the thread for Black Friday. He’ll straighten you right out.
I got two quotes from the Stealerships and the labor is priced right but....It's the price of the shocks that gets me! Up to 3 times the price I can buy OEM's for! Plus as you know Stealershlips do not want to put on after market anything!
