Do I need a 90mm MAF?
Old May 28, 2007 | 01:51 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Do I need a 90mm MAF?
I have a FAST 90mm and P&P LS2 TB and am getting a 90 mm airbridge. Do I need a 90mm MAF and if so are there TBs from any other vehicle that I can use to save on the corvette tax?
Also I am assuming that the LS2 MAF is 90mm? Thanks
Cajun
Old May 28, 2007 | 02:12 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The stock 85mm LS6 MAF works 100% fine.
You will not see any gains out of going any larger. If anything, you will create more tuning issues than anything. The LS2/LS7 MAF is actually a plug in sensor that goes into the housing. It not actually a 1 piece unit.
If you just had to do it, I would go with the LPE 100mm MAF. But it honestly wont do diddly for you...
Old May 28, 2007 | 02:14 AM
0Cajun @ Edgyvette
Former Vendor
So basically I just need to replace my stock LS1 MAF with an LS6? Is it plug and play with no tuning issues? Thanks
Cajun
Old May 28, 2007 | 03:45 AM
RED99's Avatar
RED99
You will have to change MAF table.
Old May 28, 2007 | 07:42 AM
willig72's Avatar
willig72
Cajun
Thanks Cajun for this question, I have been researching the same question. Thanks to the forum member for responding, I am sure Cajun and my self is now a step closer to knowing what we need.
Gary
Old May 28, 2007 | 09:08 AM
99 vett babycar's Avatar
99 vett babycar
Old May 28, 2007 | 09:58 AM
0Cajun @ Edgyvette
Former Vendor
So this might be a piece to install at the tuners so that he can make the changes correct? Thanks
Cajun
Old May 28, 2007 | 10:12 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Cajun
Yes.
footnote: the LPE 100mm MAF has a built in sensor that is shielded on the back side. This shields it from reversion impulses.
Louis @ LGM says it works well with high overlap cams. fwiw.
To Do I need a 90mm MAF?
