Wipers won't stop
Old Jun 26, 2007 | 08:30 PM
rgregory's Avatar
rgregory
Default Wipers won't stop
After work the wipers would not turn off. They will shift to high in the high position but in everyother position they are on low. A few times on the 20 minute drive home they parked for about 5 seconds then came on again a couple of times they acted like they were on the shortest delay cycle.
I am leaving to drive somewhere first thing in the morning and it is suppose to rain so I can't just pull the fuse. Any ideas?
Thanks.
Old Jun 26, 2007 | 08:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES! The drains in the cowl are clogged! I just posted on another post about the same thing except he had a smell issue. The controller board on the bottom of the wiper motor is in the water/gook.
Clean out the drains and once the motor controller dries out the problem should go away. Its a very common problem.
Check out the post below:
http://forums.corvetteforum.com/show....php?t=1742268
Old Jun 26, 2007 | 09:36 PM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
Yes it's the wiper motor that has been sitting in water due to the clogged udders. Your motor may dry out, but mine didn't. Here's what I had to do, (it wasn't very hard)
http://forums.corvetteforum.com/show....php?t=1715595
Old Jun 26, 2007 | 09:53 PM
rgregory's Avatar
rgregory
Thanks for the info. It rained very hard here today. When I checked the drains they were not clogged but that doesn't mean they didn't fill up in the massive drenching we got today and fry the wiper controller. Guess I will have to drive my wifes tahoe on my trip since it is suppose to rain tomorrow and the next day.
Old Jun 27, 2007 | 06:26 AM
Bville-Bud's Avatar
Bville-Bud
You might want to open up the bottom of those udders a little.
Old Jun 27, 2007 | 08:29 AM
McLude's Avatar
McLude
Or you can take it to the stealership and they will fix it for $535 because they will tell you the motor is bad... ask me how I know.. Next time, I'm checking with the CF guys. I hadn't signed up yet.
Old Jun 28, 2007 | 07:31 AM
leetownreb's Avatar
leetownreb
Default wiper problems
mine won't shut off. replaced motor, udders were immaculate!
I'm at a loss now, other than dealer.
Old Jun 28, 2007 | 07:49 AM
nitrojunky's Avatar
nitrojunky
just get the $39 autozone part. They seem to work ok after you go thru the obligatory bad first autozone motor
Actually, I'm kinda serious
Old Jun 28, 2007 | 08:47 AM
Bville-Bud's Avatar
Bville-Bud
Mine worked fine, and with a lifetime guarantee and the ability to change it out in about an hour (after the first time), it sure beats a $500 trip to the dealer!
Old Jun 28, 2007 | 08:27 PM
nitrojunky's Avatar
nitrojunky
Yeah, same here, except it took me two motors
I like the lifetime warranty for $39, but the hassle of the second motor was a pita for me. I think another poster had a similar experience so I wanted to drop the caveat.
Old Jun 29, 2007 | 11:45 AM
1965imp's Avatar
1965imp
If your motor is running and won't shut off it's not the motor,it's the wiper motor control module located under the motor. About 100.00 dollars from Chevrolet.-Very easy to fix
Old Jul 8, 2007 | 08:20 PM
Frankp57's Avatar
Frankp57
2nd Gear
Default Question
Rgregory
Did you fix the problem? I am having the same problem with IDENTICAL symptoms as you and was wondering if it was the motor or the wiper motor control. Thanks
Old Jul 13, 2007 | 07:35 PM
nitrojunky's Avatar
nitrojunky
FWIW, the $39 autozone part includes both the motor and the servo (black plastic) under it.
Old Jul 13, 2007 | 10:06 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
My car did the same thing. I fixed this a few days ago. I got a motor from autozone for about 43.00 with tax including the core exchange. Their is a install guide on the forum that makes it really easy. I used some liquid wrench on the wiper arms cuz they were a bitch to get off. Also the fuse on mine had blown too. I put a new one in and had to wait about a min or two after I put the new motor in for it to work. You will save ALOT of money compared to taking it to the dealership.
To Wipers won't stop
