Air deflector problems
Old Aug 11, 2007 | 11:08 AM
twistedb01's Avatar
twistedb01
Default Air deflector problems
I had been having problems keeping the engine cool. The center air deflector had been ripped off be the previous owner. I just got the new one in and can't figure out how to put the dang thing on. Any help would be appreciated.
Old Aug 11, 2007 | 11:24 AM
5ltrEATER's Avatar
5ltrEATER
I've been running my 97 without the center air deflector and haven't had any cooling issues...I'm not sure if putting the air deflector will help you or not!
Have you checked your thermostat, hoses, water pump, etc? Good Luck!
~5ltrEATER
Old Aug 11, 2007 | 11:34 AM
nickolbag's Avatar
nickolbag
It bolts right on. I believe its 4 bolts, 2 on each side. If you search for a Vararam install guide you may see how to remover and install the air deflector as that piece comes out during the install.
Another thing to check is the radiator, see if its blocked with leaves, grass, ect.
To Air deflector problems
