Lambo 90 vertical DOOR INSTALLATION HELP NEEDED
Old Aug 12, 2007 | 05:41 PM
Rconce01's Avatar
Rconce01
Default Lambo 90 vertical DOOR INSTALLATION HELP NEEDED
So i buy this Lambo kit so the doors can open up on my c5. I install it and after all the triming grinding and adapting i mount the shocks(possibly in the wrong location) find the torque the shocks create throws the door alignment out of wack and i find it nearly impossible to open the door up form the inside of the car even with both strong shocks installed. once the door gets 2' off the ground the the shocks help it up to its 90 degree point. Anyone that has installed a kit thats similar to this and can shed some light on to where the shocks are supposed to be mounted would be great i have spent 3 days on this so far and i am still on the drivers side. Email me if you like ralphyc81@gmail.com
Old Aug 12, 2007 | 06:46 PM
Redvette_22's Avatar
Redvette_22
Look for a post or answer by "Tomthecarguy" as he has done many of them and has all the "secrets" for them.
Old Aug 13, 2007 | 08:48 AM
Rconce01's Avatar
Rconce01
Can’t find him even did an advance search, sure you got the name right? I would really use his help
To Lambo 90 vertical DOOR INSTALLATION HELP NEEDED
