What can you expect if you put an LS6 cam in an LS1? Is it a worthwhile change?
Correct me if im wrong but an LS6 is just an Ls1 with a different top end, so maybe you can get a used ls6 top and and bolt it on your ls1 block I will be looking into this myself.
For all the trouble of getting to your cam, you'll regret it if you don't go with a bigger cam. Get the biggest cam your states smog laws will allow and that you'll be able to tolerate.
Been there, done that...went from a 2002 ZO6 cam to a 224/224 cam and much happier..
So many better choices. Even if you do it yourself its way more trouble than its worth to just goto a Z06 cam. Maybe look into the GM HOT CAM or the thunder racing "Old Man Cam" if you really want to stay small and stockish. What everyone says is true though, pick the biggest cam you'll ever think you need or want and then go one step BIGGER.
LS6's have different cams than LS1's. The Z06's extra 60 crank hp comes primarily from the cam and heads...
