Poll Does your C5 use oil?
Old Nov 7, 2001 | 10:13 PM
JOHN MORRISON's Avatar
JOHN MORRISON
Default Re: Poll Does your C5 use oil? (Richin Chicago)
No usage between changes - MN6 17,000 miles.
Old Nov 8, 2001 | 11:42 AM
maticam's Avatar
maticam
Default Re: Poll Does your C5 use oil? (C5Noir)
MY M6 I HAVE TO ADD A QUART AFTER 2800 MILES. I HAVE A 98
Old Nov 8, 2001 | 12:54 PM
Joe C's Avatar
Joe C
Default Re: Poll Does your C5 use oil? (90 Corvette ZR-1)
don't all cars use oil? sorry just bein a smart @##
90 Corvette ZR-1 -
you're not being a smart @##, just knowledgeable. ALL internal combustion engines with pressurized lubrication systems USE some oil. if they didn't, there would be something wrong with them. the consumption may be a trace amount and minimal, and may not even noticed on the dipstick, but they all consume oil!!! (so never say "not a drop") BTW, i add about .25 quart in between my 5000 mile oil changes.
Old Nov 8, 2001 | 10:43 PM
AZ C-5's Avatar
AZ C-5
99 A4...25000+ miles....No oil usage between changes :D :D
Old Nov 8, 2001 | 11:36 PM
Guest
Guest
Posts: n/a
Default Re: Poll Does your C5 use oil? (AZ C-5)
# 00827 zo6 off the line , bought it used and put 700 miles on and 3 qts mobile 1, i smell a buy back!!does any body know what vin in the zo6 started the new ring disighn?was it about the 1st quarter of the 2002 model year? :boxing
Old Nov 9, 2001 | 10:19 AM
Richin Chicago's Avatar
Richin Chicago
As an aside it is interesting to note that, so far, 52 of the 74 responses are from cars with manual transmissions. Given that manuals only account for roughly 30% of the cars sold... Well it makes me proud to be part of this forum!!!
Still 65% of the responses are MN6s! I believe, just about, a direct reversal of real world sales numbers.
Old Nov 9, 2001 | 01:47 PM
shockwave's Avatar
shockwave
My oil consumption has improved from a quart in 1300 miles to a quart in about 3500 miles. I now have about 23,000 miles on my 6sp Y2K coupe.
Old Nov 9, 2001 | 10:23 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Poll Does your C5 use oil? (shockwave)
If your C5 uses oil, It is almost certain that you have a piston ring / piston to wall clearance problem.
Take it to the dealer, tell them you have an oil consumption problem and you want them to change the oil and measure the consumption.
Dealers are doing ring/piston replacement like no tomorrow.
Old Nov 10, 2001 | 01:07 AM
Duck916's Avatar
Duck916
3000 miles on my 2001 A4, looks to be about 1/4 quart down, which is just fine with me. It might be interesting to run this poll based on the year model, as it appears the complaints of excessive oil usage increased quite a bit with the 2001s. I believe that is when GM went to the 9lb rings in place of the 13lb rings in search of reduced friction.
Old Nov 10, 2001 | 09:18 AM
Richin Chicago
Default Re: Poll Does your C5 use oil? (Duck916)
Maybe we should do that next???
Old Nov 11, 2001 | 09:13 AM
Richin Chicago
Anybody else see thier consumption dropping with mileage?
Old Nov 11, 2001 | 09:43 AM
luvinc5's Avatar
luvinc5
nah, my 99 keeps it all good
Old Nov 11, 2001 | 11:07 PM
  #33
Randy K's Avatar
Randy K
I took it into the dealer :chevy and expressed my concerns about the excessive oil consumption. He has me comming in every 1000 miles for the next 3000 miles to check it out. They also put in a dye that will allow them to see if there is any leaks. :crazy:
Old Nov 12, 2001 | 12:46 PM
  #34
rfgoss1's Avatar
rfgoss1
2002 Z06, 2087 Miles, no oil use.
Old Nov 12, 2001 | 02:25 PM
  #35
ncvetteman's Avatar
ncvetteman
Not a drop in 25k, guess I'm lucky
Old Nov 12, 2001 | 04:35 PM
  #36
Guest
Guest
Posts: n/a
A quart about every 2500 miles. Same as my 99 FRC. Drive them about the same way as well, fairly easy.
Old Nov 12, 2001 | 09:28 PM
  #37
qwikz06's Avatar
qwikz06
Default Re: Poll Does your C5 use oil? (Chalky'sC5)
I'm getting between 800-900 miles per quart on my 2001 Z06.
To Poll Does your C5 use oil?
Old Nov 12, 2001 | 09:46 PM
  #38
97silverbullet's Avatar
97silverbullet
My '97 has not ever used a drop and hope never does. :chevy
Old Nov 12, 2001 | 11:16 PM
  #39
TP C5's Avatar
TP C5
Default Re: Poll Does your C5 use oil? (97silverbullet)
No oil usage on my 99, with 13,500 miles
Old Nov 13, 2001 | 07:46 AM
  #40
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
From what I've read in various posts both here, and on other net sites, my experience of about 1 quart in 2000 miles seems to be "normal". The dealer service rep also says that this is normal, according to Chevrolet, however he and I both feel that ANY oil consumption really shouldn't be considered normal. The last car that I purchased brand new that used any oil between changes (2000 miles) was a 1971 Chevelle SS. And in the case of that car, switching from 10-30 to 20-50 stopped the consumption completely.
At $4.88 a quart, I'm not really happy about having to put in a quart every 2000 miles, but maybe the engine will "seat in" after a few more miles. By the way, it's not the $4.88 that I'm concerned about, it's just that I feel an engine shouldn't use oil, especially since I don't "beat" the car.
