Anyone else have this problem?
Old Oct 9, 2007 | 08:56 PM
1991 C4's Avatar
1991 C4
Cruise-In VII Veteran
St. Jude Donor '06
Default Anyone else have this problem?
I have a 2000 Coupe and ever since I bought it I've had a rattle in the rear. Sounds like one of the heat shields is loose but I can't figure out which one. Seems to do it the hotter it gets. I thought maybe it was a loose resinator in the muffler so I replaced them with ZO6 titanium and its still there. This is very frustrating and sounds really bad when I am sitting at a stop light. I have put it up on ramps and crawled all under it while running looking for it but it has yet to be discovered.
Help please.
Mike
Old Oct 9, 2007 | 09:30 PM
krm_wi_C5's Avatar
krm_wi_C5
Help please.
Mike
I had the same thing when I bought mine, turned out to be the exhaust tips.
Old Oct 10, 2007 | 10:42 AM
rws.1's Avatar
rws.1
had a similar problem on a 2005 SRX... it would also drome at higway speeds... It turned out to be a missing/broken weld on a baffle in the muffler.
Old Oct 10, 2007 | 11:04 AM
timemender's Avatar
timemender
Take a rubber mallet and tap on and around the underside components with engine not running and/or running if needed.
There are a lot of possibilities.
Old Oct 10, 2007 | 11:06 AM
LoneStarFRC's Avatar
LoneStarFRC
Including a loose piece of metal in the factory H-pipe crossover. There have been a few folks that have experienced this in the past.
Old Oct 10, 2007 | 04:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The tips are so close they would "jingle" when at a certain idle speed.
Old Oct 10, 2007 | 04:57 PM
krm_wi_C5's Avatar
krm_wi_C5
Yes, and I would notice it the most when city driving or at stop signs. The sound seemed to bounce off of other cars, it was very annoying.
To Anyone else have this problem?
