Top Speed Calculation???
Nov 16, 2001 | 12:26 AM
Re: Top Speed Calculation??? (Bleck)
Bleck,
Good point. I don't see Vetter having a problem with 190 either.
Nov 16, 2001 | 12:50 AM
Re: Top Speed Calculation??? (96VIPERGTS)
p2=p1 * (v2/v1)^3
P1 = Horsepower Stock
P2 = Horsepower Modified
V1 = Top Speed Stock
V2 = Top Speed Modified
Fill in P1 / V1 / P2 and solve for V2.
Nov 16, 2001 | 02:32 AM
Re: Top Speed Calculation??? (scorp508)
Quote:
EUG- THX, do you have the formula? So I can play with the #'s? Like if I change to a 3.73.
Sure can :D
Check this out
Nov 16, 2001 | 03:34 AM
Re: Top Speed Calculation??? (John Shiels)
Quote:
Your spinning that motor to 7200 with a stock crank? :eek:
YEP, works just fine. :cheers:
Nov 16, 2001 | 03:36 AM
Re: Top Speed Calculation??? (DARTH VETTER)
THX A TON for all the input. I appreciate it.
Nov 21, 2001 | 10:51 AM
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Stock coupes - .29 cd
Stock hardtop - .30 cd
Stock verts - .32 cd
What happens when you lower them?
Nov 21, 2001 | 11:59 AM
Cruise-In II Veteran
Re: Top Speed Calculation??? (Godspeed)
From the tech data I have the vert is .31
The Z06 is around that too due to side ducts, and wider tires.
