tire/rim size
Old Oct 22, 2007 | 09:44 AM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Default tire/rim size
am getting 19x11 with 295-35-19, 18x9.5 with 275-35-18 KDW.
Will this setup be ok for a 2004 without rubbing etc.?
Just want to make sure, I have checked search and there are so
many variations it confusing. But this is what I want to order.
Any problems? Thanks
Old Oct 22, 2007 | 12:05 PM
zeevette's Avatar
zeevette
You won't have any problems. I have this same combo on a fully lowered Z, and there's no rubbing.
Old Oct 22, 2007 | 01:15 PM
dadsturn's Avatar
dadsturn
So, it shouldnt be any problem with lowering the front and rear about an inch?
Old Oct 22, 2007 | 01:22 PM
Russ K's Avatar
Russ K
Just make sure that the rear wheels have a 62-65 mm offset. The front wheels need a 54-59 mm offset.
Russ Kemp
Old Oct 24, 2007 | 08:08 AM
dadsturn's Avatar
dadsturn
The offset from tirerack seems right. Questions is, will they
go past the fender? Does anyone have a rear picture showing
this?
Old Oct 24, 2007 | 12:49 PM
Russ K's Avatar
Russ K
This is my car, the tires don't stick out or rub on the inside.
http://forums.corvetteforum.com/show...&postcount=458
To tire/rim size
