C-5 NO Start Issues
The B2723 is causing the PCM to set the P1631 ... once you fix the B2723 the other will disappear.
You need to take both keys and clean the contacts on the pellets. Use a pencil eraser to burnish the metal contacts, then use alcohol or electrical contact cleaner to thouroughly clean the contacts. Insert a key without a key chain (those 28 pound keychains some people put all their keys on can add to this problem) and pull it back out ... add contact cleaner/alcohol and re-insert. Remove key and wipe off. Add more cleaner and re-insert. Do this several times as you are trying to clean the contacts within the lock cylinder.
Then try starting the car. Remember that if it won't start, there is a 3 minute "time-out" whenever an "invalid" key is used.
If the problem persists you are looking at replacing the ignition lock.
cost about 5 cents by cutting the wires as suggested you can replace your ignition at any time, they cost about $75
If so what about my door locks as they would be the original keys?
Thanks for your help!
If so what about my door locks as they would be the original keys?QUOTE]
Actually, you will have the new ignition cylinder cut to match your current key (any locksmith should be able to do it). Therefore, you don't have to worry about your door locks!
Thanks for your help. Regards, Roger
WOW. First time that I have ever helped someone from Switzerland.
I sent you a PM.
had intermittent no start- fortunatelly now it is always no start-
NO codes repeat no codes
changed starter and solenoid - no crank
VATS bypass with resistor- no crank
new ignition switch- no crank
replaced TDR - no crank
new keys- no crank
VATS relearn just for kicks- no crank
checked/cleaned grounds - no crank
checked PCM/BCM wiring and connections - no crank
BUTTT- if I, with key ON
manually jump across starter solenoid to crank motor- start and run fine
manually jump across purple and red wired at TDR to crank motor- starts and runs fine
and i think this is the most important- if i provide a direct ground from the black and yellow wire at the TDR - starts and runs every time
i have a feeling the BCM for whatever reason is NOT giving me the required ground at the TDR during cranking- when i test for ohmage to ground via multimeter with key on cranking/starting position i get infinite resistance
sooooo- if i hardwire this bypass any ideas what can/will happen? another thread poster said at some point the VATS will kick in and i will have no fuel/etc and the car wont run
ps i have checked all the fuses
this is an Arizona garaged car its whole life- dont laugh- no signs of wiring being chewed- we do get that out here
i'll owe you not a case of beer on this one- but a keg!
oh I did NOT check the auto transmission neutral safety swith- looked for threads on this everywhere and could not find any such as even where the thing is- i assume it is at the shifter
thnaks in advance!!!!!! George
1998 C5 convertible/stock except for Mich run flats and Hawk ceramic pads
How are you reading the DTCs????
Is your SECURITY LIGHT in the IPC on or flashing??
The Yellow/Black wire comes directly from the BCM and the BCM will only complete that ground path when all the cars security measures are satisfied. If something like VATS is not correct, it will NOT allow the BCM to provide that wire a ground.
Have you tried to disconnect the battery and reconnect it and then tried to start the engine? Try that.
Next
I know you stated that the car doesnt get wet BUT, if you run the AC you could have or have had moisture on the BCM. If the HVAC drains clogs it will drip inside and wet the BCM.
You can remove the BCM and remove the circuit board and inspect it for a white corrosion that can form on the bottom of the board... Also check the board for any obvious damage.
Is the wire making the circuit to the BCM? Read it out at the BCM connector.
Is the BCM functioning correctly???
If you ground the yellow/black wire and the car starts when you do all the NORMAL start stuff to start it,,,,, all the other stuff in that circuit is GOOD!
Lots of other things to check to pin down the issue.
Keep me informed on your findings.
Bill
Nice write-up.
