What did I do to my motor? :(
#63
ECS blower cam is not a "small" cam. Your valves would be hitting pistions if the chain broke. Go buy a fuel pressure tester. You need 58psi of fuel pressure...
#66
#69
Not even worth the time. If the chain broke at high RPM atleast 1 or 2 cylinders will have valve damage. If you dont want to pull the heads off,
atleast pull off all the rockers, pull out all the spark plugs and do a compression test.
#71
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please take pitures of the damage.
BC
BC
#75
St. Jude Donor '05-'08
when my timing chain went it showed the cam sensor code 1 time only. I cleared it thinking it might just be a faulty sensor which I have seen on another persons car. After I cleared it I never got another cam sensor code. It was not until I got back to the shop that I found out the timing chain was broken.
#78
I wasn't planning on forging yet but if I must I must I don't want to jump ahead on anything though as I still need to work out a problem with the P1SC head that could possibly be costly but hopefully its just a simple fix.
Keep y'all posted
