Steering Wheel shimmy
Old Nov 27, 2007 | 09:18 PM
jetmech09's Avatar
jetmech09
Default Steering Wheel shimmy
2001 vette 46,000 miles. my steering wheel shimmy's just a bit when I am on the express way. It will start @ 55mph and above. car does not pull to either side car drives straight. wheel wear is good.
Old Nov 27, 2007 | 10:18 PM
VetteTech81's Avatar
VetteTech81
Sounds like something in the front end, suspect a bent wheel, bent hub, tire balance.. What is the service history?
Old Nov 27, 2007 | 11:03 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Are the freeways there made of concrete with the rain grooves in them? If so, does the shimmy continue on regular non-concrete roads?
Old Nov 27, 2007 | 11:06 PM
TEXHAWK0's Avatar
TEXHAWK0
I would be checking the tire balancing.
Also, if you have weak shocks, you might be getting some bouncing because the shocks are not providing enough damping of the spring movement.
Old Nov 27, 2007 | 11:07 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I would check tire pressures and then if that is not the problem see if they are still in balance.
Old Nov 27, 2007 | 11:43 PM
jetmech09's Avatar
jetmech09
Thanks for all the input. I will get a balance done tomorrow. I will also check the wheels and shocks for damage. P.S. the expressways here are asphalt and concrete. thanks again.
Old Nov 28, 2007 | 12:34 PM
Gabby1992's Avatar
Gabby1992
When you get the balance done start from scratch with no weights. Bought a set of GM zo6 factory rims with KDW tires from a forum member they shook at 75 mph, took it in and had it rebalanced from scratch, some of the wheels went from 4 to 6 ozs to zero weight with the rebalancing, front end does not shake at any speed.
Old Nov 28, 2007 | 02:18 PM
Joy of 6's Avatar
Joy of 6
My vote is for out of balance. You might have thrown a weight off if it started shaking recently
To Steering Wheel shimmy
