white smoke
Old Dec 14, 2007 | 10:29 PM
500HPVette's Avatar
500HPVette
Default white smoke
I noticed a few times after driving the car for a while, shutting it off for a half hour to an hour and starting it up again the last few days, white smoke comes out the exhaust ... it doesn't smell like coolant/antifreeze or anything, and I think it goes away. I am assuming it is just condensation since it has been sub 60 degrees out recently, but if it was a problem, wouldn't a code be thrown or something?
Old Dec 14, 2007 | 11:18 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If its common water vapor such as a steam type mist that vanishes real fast, no problem. But if its white type smoke...thats another matter. The colder the weather, you will see the normal water vapor in the mornings and in really cold temps such as freezing, you will see it a lot longer.
Old Dec 14, 2007 | 11:35 PM
verano29's Avatar
verano29
Check the oil filler...any foam in there and there might be a problem.
To white smoke
