Head's Up Display Stopped working
Old Jan 8, 2008 | 06:26 AM
ACOIII's Avatar
ACOIII
Cruising
Default Head's Up Display Stopped working
Any clues? Is this going to cost me big bucks?
Old Jan 8, 2008 | 07:35 AM
Bob CTS's Avatar
Bob CTS
It did not get out of adjustment where you can not see it by chance? Did it get turned off by accident? Fuse? They are pretty good units and there are not many problems out of the HUD.
Old Jan 8, 2008 | 08:46 AM
jrose7004's Avatar
jrose7004
I'd check the fuse.
Old Jan 8, 2008 | 08:55 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Check the lever and see if it got knocked down and you can't see it now and than I would check the fuse for it
Old Jan 8, 2008 | 09:30 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Moving this to the Tech section.....maybe you'll get more help there.
Old Jan 8, 2008 | 12:13 PM
alshirey's Avatar
alshirey
I thought mine quit working, but when I leaned all the way up over the steering wheel, I could see it. It wants to adjust, but somehow it got messed up and will raise and lower....just not enough for me to see when seated. I have yet to see how much it will cost to fix.... BUT, atleast you may see it's not a fuse.
Old Jan 8, 2008 | 12:38 PM
12leavu's Avatar
12leavu
mine did the exact same thing. i was told that there is an adjustment nut on the back / bottom. you just gotta pull dash to get to it. i havent felt like doing it yet. mine went out of adjustment 2 weeks after the dealer went in the dash to fix climate control issues....i
Old Jan 8, 2008 | 04:33 PM
DeeGee's Avatar
DeeGee
I once had a problem with a dry connection on the slider
I spent ages trying to check fuses and so on. Turned out the slider was in the fully bright position but the HUD brightness was off. i recycled the slider a few times and back it came
Worth a try.
Old Jan 8, 2008 | 07:31 PM
Try the above - even if you have to replace the whole unit, it is only about $500 tops.
Old Jan 8, 2008 | 09:33 PM
Bell's Avatar
Bell
The IPC is a very robust part of the C5. There are not many problems reported. However, the HUD does have at least two cable harnesses that could be a problem. One of them connects the HUD module to the IPC. It is connected on the top of the IPC and has to be unplugged in order to remove the IPC. The other is mounted on the back of the IPC and connects the IPC circuit board to the HUD control switches. All of the connectors on both of those harnesses are friction fit only, meaning that they push together, but there is no locking tab whatsoever. They are usually quite a tight fit, but it is possible that one may have vibrated or wiggled loose. Have you recently removed your IPC to do any mods (like installing gage bezels)? If I had this problem, I'd be pulling my IPC to see if there is anything obvious. Do you know how to remove the IPC?
To Head's Up Display Stopped working
