Deterrent relay or starter?
Old Jan 29, 2008 | 12:58 PM
vincentjames501's Avatar
vincentjames501
Default Deterrent relay or starter?
Car finally wont start . When I turn the key I hear a click. Have no idea what it is. We just popped the clutch and the car started that way. I don't want to invest a lot of money into a starter if that is not the problem. For some reason I think it is though. I don't have a voltmeter to measure the voltage of any wires. Anything I can do?
Old Jan 29, 2008 | 01:05 PM
BlackZ06's Avatar
BlackZ06
A few possibilities ....
1) weak battery
2) bad starter
3) wiring to starter is loose
First thing I'd do is see if there are any codes posted in the computers. If nothing posted, then next time you try to start the car and all you get is a click, try a jump start. Usually, though, a low battery will cause you to hear a series of clicks, not just one.
I'd next check the wiring to the starter .... BE CAREFUL, the starter is directly connected to the battery so either disconnect the battery before checking the wiring, or be very aware that there is a hot wire that you don't want to ground.
There are several posts by Bill Curlee on wiring issues to the starter.
If the Theft Deterrent system was causing the no start, you would not have been able to keep the engine running after starting it by popping the clutch. Unlikely you have a Theft Deterrent issue, but again, the codes will tell ....
Old Jan 29, 2008 | 01:14 PM
vincentjames501
No codes. This happened to me before and my reasons for doubting the battery to be the issue is me and my brother tried to jump start my car with jumper cables and no go. So does that leave me with the starter? I even had him rev his car up and absolutely nothing. Anybody know a cheap place to get a starter from?
Old Jan 29, 2008 | 03:02 PM
BlackZ06's Avatar
BlackZ06
Check the wiring to the starter first. There have been some people who have found that the wires have come loose, and tightening them back on the starter solved the problem.
For a "cheap" starter .... next post .....
Old Jan 29, 2008 | 03:19 PM
BlackZ06's Avatar
BlackZ06
Napa Auto Parts lists the "cheapest" re-built starter at $144.00 (Part number RAY2465126)
The GM part number for the starter for a 1999 is 10465385 - not clear if this is new or also re-built .... list price is $360.47 but places such as ...
http://www.gmpartshouse.com
http://www.gmpartsdirect.com
should carry it for about 1/2 that price. Check other auto parts suppliers (Pep Boys, Kragen, etc.) that may be local to you.
Old Jan 29, 2008 | 03:22 PM
vincentjames501
Anything in particular I want to check for to see if there is a ground problem? I know nothing about electrical issues.
Old Jan 29, 2008 | 06:06 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Vince -- If we have to go that route, I can get you a rebuilt starter at AZ for $155, or a brand new one for $170.
It's either going to be the wiring or the starter itself. I would be surprised if the wiring came loose given I cranked them down pretty good, but anything can happen. Just come on over to my place on Saturday like we talked about and I'll get you set straight.
Old Jan 29, 2008 | 10:32 PM
allmee's Avatar
allmee
Did you check the relay in the fuse box under hood? Mine went bad, but I can't recall if I got a click or nothing at all! Might have been nothing at all! My memory is not like it used to be!
Old Feb 3, 2008 | 11:12 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Vince's car is fixed guys. He brought it by this morning. The starter solenoid was obviously clicking when he keyed it, but the starter itself wasn't doing anything. After some poking around, I took a VERY close look (as good as possible through the big Kooks headers at least) while he keyed it and noticed that the solenoid connection to the starter arced when he hit the key. Pulled a couple of plug wires and snaked my hand down around the back of the header to the bolt and sure enough, the one bolt that never gets touched was loose. Couple of long socket extensions later coupled with a u-joint and 13mm socket and the car fires up on it's own again!
I for one am tremendously glad it was just that bolt, because unbolting a header to R&R a starter isn't my idea of "fun" car work. I just am amazed that the ONE bolt that no one ever has to loosen or tighten is the one that came loose for some reason. Just mind boggling.
Old Feb 3, 2008 | 11:59 AM
vincentjames501
Thanks for the help buddy!
Old Mar 15, 2008 | 06:35 AM
abraham's Avatar
abraham
Possible to explain better on how to find this bolt? I believe I have the same problem.
Old Mar 16, 2008 | 08:28 AM
abraham's Avatar
abraham
Please ignore the above post. I found Napa wants around250 for a starter. Found it at gm parts direct for 187. Just updating what I found.
Old Mar 16, 2008 | 10:27 AM
abraham's Avatar
abraham
Hard to believe but United Auto Parts here in MI said they can order me one(starter 97 vette) for $93
Cant beat that
To Deterrent relay or starter?
