Swapping Climate control heads
Old Feb 11, 2008 | 07:01 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default Swapping Climate control heads
how universal are the Dual Climate heads?
i.e take one from a Trailblazer (size aside), will it work in my C5? I doubt if it will plug right in, as long as the pin I/O's are the same, that would be a simple matter of making a molex connector.
Old Feb 11, 2008 | 07:48 PM
Greg_E's Avatar
Greg_E
I don't have the answer to your question, but if you are changing it because the LED's are dim, there is a DIY fix for that. The surface mount resistors have bad solder joints. Easy fix.
http://forums.corvetteforum.com/show....php?t=1583758
Old Feb 12, 2008 | 05:44 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
Yes, I am aware of that fix. I've fixed mine and soldered a few others.
I was wondering for general info, just passing through my skull, so to speak.
To Swapping Climate control heads
