Oil pressure problem!
Old Feb 22, 2008 | 11:23 AM
bigjohn2's Avatar
bigjohn2
Default Oil pressure problem!
I bought a new oil pressure sensor and that went bad, my needle was reading 80 psi again after a week, well I was driving home from work and my pressure dropped to 0 and shot back up to 80, the needle was going crazy so I pulled over and shut the car off. I waited a few minutes and started the car back up the needle stayed at 80, I took it home and it's been sitting there since still no valve train noise no knocking or nothing, what do you guys think, can a bad sensor still tell you that your oil pump is bad?
Old Feb 22, 2008 | 11:31 AM
Oldvetter's Avatar
Oldvetter
Was your old oil pressure sensor leaking oil? Did you clean the electrical connector good? If not, it could be a bad connection.
Never heard of a sensor failing with a low pressure. BUT, if no valve train noise, you should be okay. High readings are definately due to sensor.
Check pressure with ignition on and engine off a couple of times. High readings are bad sensor.
I don't think a bad sensor would indicate 0 if you had no oil pressure, because it doesn't indicate zero when ignition is on and engine is off (no oil pressure).
Old Feb 22, 2008 | 11:37 AM
Mike94ZLT1's Avatar
Mike94ZLT1
What does it say on the DIC?
Old Feb 22, 2008 | 11:45 AM
bigjohn2's Avatar
bigjohn2
The old ones didn't leak but when I turn the ignition on it does read high oil pressure but a couple of times it read 0 pressure. to me it sounds like lose wiring, I think I'll start with the easiest job which is the sensor and work my way to the hardest job the pump itself, I'm kicking myself in the *** because i was just looking at it 2 weeks ago and didn't change it. lesson learned
Old Feb 22, 2008 | 11:46 AM
bigjohn2's Avatar
bigjohn2
The DIC read 130 psi
Old Feb 22, 2008 | 12:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its a common failure. Turn on the key without starting the engine and look at the oil pressure. If it maxes out, your sensor is bad. There is a sticky at the top of this section regarding this issue.
Old May 24, 2008 | 10:05 AM
ILM-Express's Avatar
ILM-Express
MFIC
I have changed a few of these for the same problem. Bad Oil Pressure Sender
To Oil pressure problem!
