listen im in need of all the assistance i can get...
I own a 2000 corvette... and it needs a clutch done..
Im a ford master tech, working at a ford dealership.. so i have access to a lift and everything...
what i dont have access to is ... the R&I labor workshop manual on how to remove and install the transmission...
Well you have to drop the rear suspension to start,and you have to make sure the engine is supported to a certain point to make sure it does not fall in to the firewall,check this guy out: http://www.cajundude.com/c5techhome.htm
