Your explanation is vague .... you installed new wheels (rims) with TPMS .... are they a "new" set of TPMS ..... or are they the old ones ??
Are the old ones still in proximity to the car ... such as sitting in your garage on the "old" wheels ??
The TPMS cannot "program themselves" ..... any more than they can procreate or clone themselves .... they are a pressure sensor and a radio transmitter ... that is all they are ....
If you have "new" sensors on the car, you should re-program the car ASAP ... it is about a 5 minute project that requires a fairly strong magnet (like a speaker magnet) to perform the task. The only way you would get your hands dirty doing the re-program is if the magnet is dirty.
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I just changed wheels, I have a procedure to "learn" the sensors. A magnet is needed and some DIC procedures! Sorry I can't walk you thru it right now but it is on this forum somewhere, try a search!
yes it is possible. if you disconnect your battery for the winter like i do and reinstall it in the spring the tps sensors will all read blank until you drive the car and get the wheels spinning for about 1/2 mile. then, the sensors wake up and the readings just come back on their own. its totally normal.
Silverbullet00 I just changed wheels, I have a procedure to "learn" the sensors. A magnet is needed and some DIC procedures! Sorry I can't walk you thru it right now but it is on this forum somewhere, try a search!
Tried the magnet trick...it worked!!!! Good thing i did it too, they were all at 22psi All fixed now and filled to 30psi...thanx for all your help guys
