drive shaft coupler
Old May 10, 2008 | 08:14 AM
vjjack04's Avatar
vjjack04
Default drive shaft coupler
Some of you refer to an ECS aftermarket joint to replace the rubber torque tube coupler; can someone give me the website link?
I have a '97 and have significant power over stock; would a z06 coupler work? Is it different than the coupe?
Old May 10, 2008 | 08:48 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The Z06 torque tube is heavier than the 1997 - 2000 torque tubes. Any manual 2001 torque tube is the same.
ECS makes a solid coupling with some other modifications to the joints.
Old May 10, 2008 | 09:30 AM
vjjack04's Avatar
vjjack04
I appreciate your response.
The lower one in the picture has a traditional joint; is take it that is the z06 shaft. So I assume that the ideal set up is a z06 shaft and the alluminum spacer/connector?
Old May 10, 2008 | 09:31 AM
vjjack04's Avatar
vjjack04
Also, what is the website for ECS?
Old May 10, 2008 | 09:35 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The Z06 style tubes came out in 2001 for the manual transmission.
ECS uses a traditional U-joint and a solid coupler.
http://eastcoastsupercharging.com/
To drive shaft coupler
