Help Needed, Changed Rear Pads, Get 1264 Code, Won't Clear
Changed Rear Disk Pads last night. Unbolted Caliper, Used piston press to move pistons in, changed pads, reinstalled calipers, bled brakes RR first, LR second, Got 'Check Active Handling' Alert, 1264 Code, Yellow Active Handling light and Red Brake light symbols on dash are lit. Car stops fine, no noise, no leaks. Any suggestions?
FIXED! It was the C1247 H C Code, not the C1264 (My memory is really getting bad). Brake differential pressure was detected during bleed process, makes sense. Just reset the Codes, the right way and all's well. Yea!!!!
Reason: Problem fixed
