Speedo calibration
Old May 30, 2008 | 04:19 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Default Speedo calibration
My speedo (cluster and HUD) are a bit off since Ive put on new tires with a smaller profile.
I also have a pioneer Z2 and it has setting under maps that shows you your direction of travel and your speed.
It looks to me like the speed being shown by the Z2 is correct, but its hooked up to the vehicles VSS. Unless its the gps antenna unit that is deciding the speed.
At about 120 km/h shown by the hud, the Z2 will read ~114 km/h.
I take it you need a programmer to fix the speedo?
Old May 30, 2008 | 08:52 AM
LDB C5's Avatar
LDB C5
It's probably using the GPS system to calculate speed and if so, the faster you go the more accurate the speed display will be.
You do need software to reprogram the speedo.
Old May 30, 2008 | 12:52 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
What I thought, Thanks.
Old May 30, 2008 | 01:08 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The GPS is probably correct, but the car's speedo is off due to the new tire height. You can go into the computer with many tuner software systems and tell the computer what the new REAR tire height is. It will them adjust your speedo based on calculated distance travelled per tire revoltion.
Old May 30, 2008 | 01:23 PM
Bill Dearborn's Avatar
Bill Dearborn
You are off about 5%. That puts you in the 25.3 inch tire diameter range. Did you switch to 315/35/17s or 275/35/18s (that is their diameter) by any chance?
Bill
Old May 30, 2008 | 01:31 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I went from stock front and rear sizes- 245/45/17 and 275/40/18 to......245/40/17 and 275/35/18.
So the car is showing me faster than what Im really doing, not a huge number but still off.
According to my calculations my front diameter is 24.716" or 24.7" and the rear is
25.578 or 25.6".
Old May 30, 2008 | 01:32 PM
hotwheels57's Avatar
hotwheels57
Plug your oem tire sizes and new tire sizes into this tool, scroll down a bit and it'll tell you % of speedometer error, indicated and actual speeds...adjust you speeds accordingly.
http://www.miata.net/garage/tirecalc.html
Old May 30, 2008 | 01:51 PM
doje's Avatar
doje
25.578 or 25.6".
The car only cares about the rear wheel height. That is where is gets the speed from. Thus the reason that your speedo will go way up during a burnout even though you are standing still.
Old May 30, 2008 | 02:33 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yup, Im aware of that, I was just stating the new tire sizes is all.
To Speedo calibration
