blade fuse
Old May 30, 2008 | 07:22 PM
bowtiebubba's Avatar
bowtiebubba
Default blade fuse
What size blade fuse does the C5 use? Need to buy a tapa circuit,do they use a mini or maxi,ATC or ATM?
Old May 30, 2008 | 08:26 PM
ZeeOSix's Avatar
ZeeOSix
Not sure ... maybe the Owner's Manual specifies which kind.
Old May 30, 2008 | 11:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Actually our C5s have three different sizes. Maxi, mid-size ("standard") blade fuse, and minis.
The size depends on which particular circuit you are working on.
HTH
Old May 31, 2008 | 02:30 AM
ZeeOSix's Avatar
ZeeOSix
HTH
I just looked in the Owner's Manual (2002), and this is what it says:
"Fuses and Circuit Breakers
The wiring circuits in your vehicle are protected
from short circuits by a combination of maxi-fuses,
mini-fuses and circuit breakers
Also, it shows a few pages of where and what the fuses are, as well as if they are maxi, mini fuses or circuit breakers.
Old May 31, 2008 | 04:55 AM
LoneStarFRC
Yikes. I think you're right. :o I have a couple of aftermarket items added to my car (subwoofer amp) that use the ATO (standard size blade fuse) and I keep a few spares in the car for that purpose, along with a selection of minis just in case. Guess I was inadvertantly thinking of them along with others.
bowtiebubba: Unless you're adding an item that has a fairly high current draw, looks like you need the "tap-a-fuse" for the minis. Preferrably, whatever you're adding has it's own fuse too and won't have to rely strictly on the fuse being tapped into.
Old May 31, 2008 | 07:36 AM
bowtiebubba
Thanks guys.
To blade fuse
