Exhaust Cross Pipes vs Tru-X Cross Pipes?
If you swap your stock H-pipe for an X-pipe it make the car QUIETER and more mellow. Made a huge difference on my Z06, it was loud as heck and popped and cracked on deceleration and I put the X-pipe on and now it's smooth and mellow with no popping.
Same thing on every single Mustang I've seen, H-pipe gives it that loud muscle car sound and the X-pipe gives it the smooth more exotic sound and is always quieter.
Interesting. My car pops and burbles like crazy now, which I can't blame solely on the cats. Was your Z stock? The Z catback is much more quiet than the Stingers I have. Supposedly at the extreme quiet end of all low restriction options.
I had longtubes, no cats, stock H-pipe, and Corsa Pacecars and it popped and cracked like crazy, swapped a Borla X-pipe in place of the stock H-pipe and 75% of the popping and cracking disappeared. I traded the Corsa for a Borla Stinger so now it's longtubes, catless, X-pipe and Stingers and I absolutely love it and get compliments on the sound all the time.
I have corsa indy exhaust that screamed at wot and after adding the corsa x-pipe
it no longer screams.
St. Jude Donor '09-'10-'11
Anyone know of a website that has recorded sound of the different exhaust systems? It would be great to have a few examples to hear.
What would be the results of no H or X pipe? Years back we use to have side pipes on the Vettes with no connection from bank to bank.
Eric D
Eric D
Eric D
Eric D
www.youtube.com
the h-pipe is not really connected. It has a large support pipe with a hole between them the size of a dime. So i would consider an h pipe as two straight pipes to the mufflers.
[QUOTE=VIPERBLUELX;1565822746]I had longtubes, no cats, stock H-pipe, and Corsa Pacecars and it popped and cracked like crazy, swapped a Borla X-pipe in place of the stock H-pipe and 75% of the popping and cracking disappeared. I traded the Corsa for a Borla Stinger so now it's longtubes, catless, X-pipe and Stingers and I absolutely love it and get compliments on the sound all the time.[/QUOTE
I definitely am not into the same level of sound that you are. I hate my Borlas but they were on when I got her. Would much rather have the Corsas or stock Z ti. I had an 03Z and I thought the stock tire and exhaust were annoying because of the lack of sound deadening. Of course I took both the Z and my current vert on long distance road trips so the throatiness gets a bit old after a while. Must be the old guy thing. I don't crank the music up as much either
It appears that, tastes aside, mixing and matching components will result in different levels of burbling, drone, popping, or resonance with each combination. Since adding the x pipe it does have a fuller sound at low rpms, but as soon as I get into any boost I am getting it coming right up through the floor.
[QUOTE=nuck;1565824458]
My Corsa Pacecar exhaust was as loud as my Borla Stingers, so you if you happen to swap you better get the Corsa Touring.
I defintely am not into the same level of sound that you are. I hate my Borlas but they were on when I got her. Would much rather have the Corsas or stock Z ti. I had an 03Z and I thought the stock tire and exhaust were annoying because of the lack of sound deadening. Of course I took both the Z and my current vert on long distance road trips so the throatiness gets a bit old after a while. Must be the old guy thing. I don't crank the music up as much either
Nuck,
I tried the files on my work computer today and they work fine. Must have something to do with my home computer and Vista???
Thanks again,
Eric D
Thanks again,
Eric D
#33
According to Roush Racing the closer the X pipe is to the headers the more hp it makes. Several years ago Rusty Wallace won 3 of 5 races in a row and was in the top five in the other two. Unfortunately he was in a terrific accident the next race and flipped over. Thats when all the competitors found his X pipe was right after the headers and all of NASCAR soon followed.
#34
#35
Different style of x pipe known as a 2x2
#37
ones with the merge style collectors (also known as 2x2) , nascar style
http://www.corvettegarage.com/produc...-corvette.html
Some people will even put an x-pipe right after the headers to replace the cats and have another x cross pipe at the rear.
#38
2x2 xpipes are used right at the collectors to replace your cats.
http://www.yourperformancesource.com...ROD&ProdID=736
Call em whatever you want they are all still x pipes but when you talk about replacing your cats or your h-pipe i think what we are sold 2 different kind of x pipes.
Confused yet?
http://www.motorsporttech.com/images/c5/xpipe01.jpg
http://www.allpar.com/history/mopar/x-pipes.html
#39
Confused yet?
The "allpar" website calls it "black magic" but I would like to believe that someone out there understands the reasons why it helps or not. Maybe someone into fluid dynamics.
Anyway, thanks everyone for explaining the 2x2 x pipe. One more thing to add to my brain
Eric D
#40
Just a tad confused.......well, ok - maybe a little more then a tad but I find it very interesting.
Eric D
Eric D
http://www.drgas.com/articles/art_paulhaney.php
