AC Delco plugs are not always OEM for GM!
Location: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Last weekend I started the tune-up on our 2000 Pontiac Trans-AM LS1 (practically same LS1 engine as in our 2000 C5 ).
We are the original owners, plugs had NEVER been changed, but with 110K, the plugs were way overdue (pinging was noticable even at 2500 rpm).
Boy was I surprised when I pulled-out the first driver side plug and saw it was NOT an AC Delco, but a DENSO (12563707 - PTJ16R15).
Further, the wires were all labeled with a 'Packard' name, contrary to the replacement AC Delco wires, which did not have that same label.
So, whereas GM may be putting the not-so-well-liked AC Delco platinum plugs and wires in our Corvettes, it would appear that someone at Pontiac realized the problem with that selection, and decided to NOT use AC Delco as OEM in the 2000 TRANS-AMs.
BTW, the plugs were really shot (center electrode was still flat, but the edges were rounded, HOWEVER, all the platinum pucks were still there, unlike AC Delco's (e.g. on our 94 LT1).
FYI, decided to install NGK's 100k OEM Laser Iridium (ITR5F13 - 6044 -- iridium center electrode with a platinum puck on the ground electrode) and have noticed a big improvement already with only having done the driver side (OMG, the passenger side may require removing the engine -- Fbodys ouch).
...and that is the reason you have them...in 2001 some of us got the Denso's from the factory...my 2001 Corvette got Denso's right from the factory (I checked when the missing puck thing came up around that time)...Packard makes the plug wires for GM too...remember that there are reasons for the changes, strikes by plants producing the parts, running changes...etc. fear not.
Bill
Bill
Old news. My 1999 C5 came with Denso plugs as OEM. Also, as far as I know Packard is owned by Delco.
Sorry, I didn't know the AC Delco plug puck problem was eliminated by a switch to Denso starting circa 1999.
I had direct experience (our 94 was missing 3 pucks) that the AC Delco's were still a problem for the C4's (due to limited AC Delco choices), and assumed the problem continued into the C5s until the TSB on the Iridiums was published by GM.
My bad -- I had only lightly followed the issue for our C5 as ours has only 10k and figured I had years before I had to worry about it.
To Craig04c5, thanks for the suggestion -- I had planned on trying that approach -- so hopefully with a new box of bandaids, I'll get the passenger side done next weekendl
BTW, several of my Denso OEM plugs on my '99 had missing pucks first time I pulled them.
Wow, thanks for the offer, it sure would be easier having someone else who's done it, right there to share in the misery and beer -- anyway, I'll let you know how I make out.
Premium Supporting Vendor
The Iridiums are now the standard replacement for the LS series of engines.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Originally Posted by Mike Mercury
yep; my 2002 had Denso's... and I also read about a connection between Delco and Denso
Mine were to, but I thought they were replacements. Didn't know they came with them until I read this thread.Must have been origanal plugs 86K on them
