Tach Wire Enough Voltage ?
Old Jul 20, 2008 | 11:44 PM
Tourmgr1's Avatar
Tourmgr1
Default Tach Wire Enough Voltage ?
Anyone hooked up a G2X RPM feed and a Raptor shift light to the same RPM source white wire found under the dash ?
Will I have enough voltage to power both ?
TIA
Old Jul 21, 2008 | 11:31 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
The tach is a signal, not a voltage. Yes, it should work both.
Old Jul 21, 2008 | 12:49 PM
Tourmgr1's Avatar
Tourmgr1
Thanks,
I appreciate the reply and I think you're correct ....just wanted to save time and thought others might benefit from the question (which was was not well put).
I opened this thread in the Autocross and Road Racing Forum and so it would be better to close this and continue there.
http://forums.corvetteforum.com/show....php?t=2083423
To Tach Wire Enough Voltage ?
