Oil catch can in 2000 Vert
I installed an oil catch can in my 2000 vert today. It was pretty easy to do. Just remember, PCV into the top of the can, hose from the intake into the side of the can.
Just for kicks here is my moded engine bay:
And to make it worse, the can oozed oil out the bottom o-ring. The vendor replaced it, and the new one oozed also! So, off it came.
From what I read here, I believe that most of the oil in the intakes of cars like mine that aren't tracked or driven too hard, comes thru the breather hose in front of the throttle blade, when we stomp the gas and lower the intake vacuum. This reverses the PCV flow, and the airflow thru the intake bellows pulls the oil from the valvecover area.
DG
DG
u called him daddy
Oil in the intake leads to carbon buildup on the pistons which over time, can raise the compression ratio above the piston. Higher compression ratios require higher octane, without which results in pinging and intervention by the ECU to eliminate this condition - bottom line: a loss of power.
Of course, it gets even more complicated when varying throttle positions change the pressure characteristics of the blowby gases, but as a general rule, keeping oil out of the intake can only be a good thing.
Dave68 , I and others have said over and over that the effectiveness of any OCC has many variables. Not all OCC's are created equal. Most are just empty cans with an inlet and outlet, nothing to hold or seperate the moisture and oil from the air. Those that have a small amount of material to aid condensation ( SST mesh or non metallic fiber) don't trap contaminates. The designed mounting location is for convience as the location is a direct source of heat which defeats the function ( condensation ) of the can. Ifthat mounting location is going to be used , may i suggest using an insulator between the head and mounting bracket ( a heat resistant polymer plastic) and a heat shroud (SST or aluminum) to deflect direct heat from exhaust and head.
With the effects of oil blow by and crankcase gases returning to the combustion chamber thru an ineffective PVC system, I use two Mike Norris OCCs that are modified with seperator filter (Wilkerson) and coalescing filter (Binks) that are mounted low on the radiator support. Two reasons for this , cooler location and the feed and return lines offer a drain back .
The effects of oil entering the combustion chamber , carbonizing everything ; valves , pistons, rings, cylinder head, ect . The altered fuel /air mixture i.e. reduced power, ect. The probable failures of the MAFS, O2 sensors, Cats. Possibly not passing emissions tests for any numbers of the effects listed. Any thing that will optimize the reduction of oil consumption is a plus in reliability, performance.
DG
Who's your Daddy??????
DG
