2001 6.0L truck engine ?
Old Jan 2, 2002 | 12:24 AM
madguy's Avatar
madguy
Default 2001 6.0L truck engine ?
is the 2001 6.0L truck engine in the chevy silverado the same one that is in the new cadillacs?
Old Jan 2, 2002 | 12:31 AM
Closer_2001's Avatar
Closer_2001
Default Re: 2001 6.0L truck engine ? (madguy)
Caddy gets more compression and 345 ponies. Same basic design. Not sure about the heads?
Old Jan 2, 2002 | 12:45 AM
Ripped427's Avatar
Ripped427
The pistons are different for higher compression.. The heads have the same part #'s. According to some of the guys posting at LS1tech.com. The timing and fuel curves are were the rest of the power comes from. I dont' know about the cams between the trucks and SUV's though.
Dennis
Old Jan 2, 2002 | 01:00 AM
madguy's Avatar
madguy
Default Re: 2001 6.0L truck engine ? (Ripped427)
I guess that isn't bad considering I am getting a good deal on a complete engine that I am going to use to build for the Z06. I guess the only drawback is the heavier block. What do you guys think?
By the way I am considering this motor for a supercharged application.
Old Jan 2, 2002 | 11:20 AM
99 Corvette's Avatar
99 Corvette
From what I've heard the block is only about 40-60 lbs more. I think this would work great with a supercharger :cheers:
Jerry
Old Jan 3, 2002 | 06:53 AM
Skeeter1's Avatar
Skeeter1
I have that block in mine and will be installing a mallet carbon hood and BP nonpopup headlights to bring the weight bias very close to stock. :cheers:
To 2001 6.0L truck engine ?
